Results 1 to 10 of 11
November 22nd, 2010 01:56 AM #1
[IMG]file:///C:/Users/RGL%7E1/AppData/Local/Temp/moz-screenshot.png[/IMG][IMG]file:///C:/Users/RGL%7E1/AppData/Local/Temp/moz-screenshot-1.png[/IMG][IMG]file:///C:/Users/RGL%7E1/AppData/Local/Temp/moz-screenshot-2.png[/IMG]
Guys, where could this oil leak possibly coming from? anyone here experienced the same problem with mine?
I've already replaced the following gaskets and oil seals: ,
VALVE COVER GASKET
OIL SEAL DRIVESHAFT LH
SHIFTING ROD OIL SEAL
CRANKSHAFT OIL SEAL
OIL PAN GASKET
am i missing out something? i really need your inputs. thanks in advance.
November 22nd, 2010 01:06 PM #2
chief we have a the same problem. is your oil seals crank & cam shaft is HONDA GENUINE..? if not yun ang problema.. iv bought a replacement parts they say its Japan made but the problem is..hindi talaga sila TUGMA sa sukat even doe they've been measured by some autoshop.. twice na ako nagpalit ng oil seal when my mechanic saw my oil seal are replacement.. he totally told me that bumili ako ng Genuine parts HONDA mismo.. to tell you honestly pricey siya talaga ng 150php.. replacement parts kasi nasa 130php so dapat dalawa 260php i bought it sa FERTES. but from HONDA SPA i bought it by 250+ so dalawa mga 500-515php lahat.
Kung ako sayo buy a genuin parts sa HONDA mismo, ganun din ang suma kung papalit-palit ka ng oil seal.
November 22nd, 2010 02:41 PM #3
cam shaft?
ive been using replacement seals for a long time and it never gave me problems. the best is take out the cover sa timing belt then see if the leak is coming from there.
lakas ba tagas ng engine? how many times do your refill oil? palinis mo muna yung mga oil tagas kasi its much easier to track down a leak with a clean engine.
edit: matic o manual?
November 22nd, 2010 05:21 PM #4
November 22nd, 2010 09:06 PM #5
November 22nd, 2010 11:50 PM #6
Yes sir Hondabot, genuine yun parts na naikabit dahil sa CASA ko sya pinagawa, nadala na ko sa replacement nadoble gastos ako sa parts and labor hindi nagfit yun nakabit ko dati kaya pag Oil seals and Gaskets sa casa ako bumibili and nagpapagawa para sigurado pero hindi lahat ng gawa nila pulido,last time nagpagawa ako nakalimutan nila higpitan ang Top engine support ko kaya makalampag,pinababalik ako pero kami nalang naghigpit kaysa babalik pa ako sa casa malayo sa bahay sayang ang gas. nasigawan ko tuloy yung SA nila hehe
Anyway it might be the cam shaft, i can't remember replacing it yet. sana tama si sir archie123456789. M/T yun EK ko sir. Already had an under car wash pero meron pa din yun leak. Patak patak lang naman siya. Thanks for your inputs mga sirs.
November 23rd, 2010 12:36 AM #7
nasa logic ko naman na kung palit crankshaft seal, dapat pati cam shaft napalitan. im not exactly sure but there are only a few seals that would cause the oil to leak. since sa casa nagpagawa, pahanap mo sakanila yung leak then tell them to show it to you if they found it.
sir hindi kaya tranny oil? nagrerefill ba kayo ng engine oil every now and then? kasi if no and level naman engine oil, baka tranny oil na may tagas.
- Apr 2008
- 112
November 23rd, 2010 10:16 AM #8front crank shaft oil seal, kung cavite ka, bring it to mel casaba
http://www.sulit.com.ph/index.php/vi...r+/+Specialist
God Bless
November 23rd, 2010 11:33 PM #9
Thank you guys, try ko muna yun Camshaft seal sana yun nga. It could be tranny oil din kasi Engine oil ang gamit sa transmission instead of gear oil na nililagay nila sa transmission. Masydo daw malapot ang viscosity ng gear oil for honda's transmission. I'll just have it checked this coming weekend. Sana magawa kaagad. btw im from QC sir bong06.
November 24th, 2010 12:18 AM #10
Suzuki JIMNY [merged threads]
