Results 1 to 17 of 17
    May 2009
    I have a Honda Civic 1996 Lxi, and it is not compatible
    with E10 Gasoline, anybody knows a Non-E10 Gasoline
    available in the market?
    Is Petron Blaze 100 Non-E10?
    Thanks in advance.
    Jun 2005
    Quote Originally Posted by TheNaughtyCrew View Post
    Thanks in advance.
    bkt di compatible? kahit yung 1978 lancer at corolla SB namin compatible.
    pati yung 1997 civic VTi compatible din sa E10.
    anyway, petron advertised that blaze has no ethanol
    Sent from my Thrill 430x using Tapatalk 2
    Jun 2004
    Blaze alam ko walang ethanol, yan lang din pwede sa old cars namin since nde sila e10 compatible. Tatakbo naman yung civic sa gas na e10 kung wala ka talagang choice, long term baka mag ka issues lang sa fuel lines or hard starting.
    Oct 2013
    Paps E10 ba talaga sya incompatible or mababalang yung octane rating na naikarga mo? Kasi yung E10, halos wala effect talaga sa blend.
    Jul 2011
    pa drain mo ung fuel tank, then limit mo lan ang karga mo ng 1,000 pesos para laging napapalitan un gas. observe mo din un gas station na pinapakargahan mo baka lumulubog sa baha.
    Oct 2013
    Kasi paps, yung E10, ibilad mo ng ilang araw sasakyan mo, baka di na nga 5% ethanol content nyan hehehe...
    E10 is compatible with fuel injected engines.
    Your car variant is LXi, therefore, fuel injected na sya.
    It can go well with the 91 octane or the 95 octane variant.
    I think no need for a non-e10 gasoline variant..... wala ka na din namang makikitang ganun dito ngayon eh..... i think even blaze is e10 based.
    May 2009
    Quote Originally Posted by sirkosero View Post
    Bro, nabasa ko kasi dati sa Honda Website na hindi compatible yung mga Honda
    Civic 1996 model sa E10 Gasoline.
    May 2009
    Quote Originally Posted by chris_d View Post
    napansin ko kasi kapag E10 Gasoline ang karga ko, halos walang hatak,
    pero kapag mga 97 to 100 octane rating ramdam yung lakas niya, walang
    tiyopeng tunog... plus nagtu-tubig yung exhaust ko, kahit mainit na yung
    makina may tubig pa rin sa exhaust.
    May 2009
    Quote Originally Posted by vvti2.0 View Post
    I usually load Caltex Gold, yun kasi libreng Gas ko from Office, kaso mahina talaga
    hatak, plus nagtu-tubig yung exhaust, kahit mainit na makina may tubig pa rin.
    May 2009
    Quote Originally Posted by Manilablock View Post
    hindi ko talaga pinatatagal yung gas ko, kasi sabi nila napapanis daw yung
    E10 Gasoline... regarding kung binabaha yung gas station, negative, hindi
    binabaha yung kinakargahan ko.
    May 2009
    Quote Originally Posted by 1D4LV View Post
    Nabasa ko kasi dati na hindi E10 compatible yung Civic ko, plus mahina talaga batak
    compare sa mga 97 to 100 octane rating gasoline... plus nagtu-tubig exhaust ko kapag
    naka E10 ako (Caltex Gold), kahit mainit na makina may tubig pa rin.
    Yung Petron Blaze 100 wala raw Ethanol, tinanong ko na sa Petron, kaso may iba pa
    kayang Gas Station na walang halong E10?
    Jul 2011
    kelan mo ba napansin ung problem sa car mo, kasi ung e10 ang tagal na sa market. baka hindi naman fuel ang prob.
    try mo magpalit ng air filter baka marumi.
    Oct 2013
    Water in the exhaust means your catalytic converter is working efficiently and means also there is nothing wrong with your engine, full combustion ang nangyayari. Hindi napapanis ang may E10, mas maigi nga na tumatagal kasi nababwasan ng ethanol hehehe.. At mahina talaga hatak dahil sa ethanol.
    May 2009
    matagal ko nang napansin, since early 2012 pa, kaso last 2013 nagpa-top overhaul
    ako dahil nagkaron ng leak yung gasket ko going combustion chamber, sobrang lakas
    ng labas ng tubig sa exhaust, nag-simula yun sa simpleng labas ng tubig sa exhaust
    pero di nagba-bawas tubig ko sa radiator... hanggang sa bumigay, nauubos tubig ko
    kaya nagpa-top overhaul nako, ok naman, naayos na, wala nang overheat, kaso
    yung tubig sa exhaust hindi totally nawala, althought wala ulit bawas ng tubig sa
    radiator, iniisip ko kasi baka dahil sa E10 kaya nagkaron ng leak ang gasket ko, kaya
    humahanap ako ngayon ng Non-E10 gasoline bago pa ulit bumigay gasket ko...
    possible kaya na dahil sa water content ng E10 kaya nasisira ang gasket?
    regarding airfilter, kakapalit ko palang, lagi ko rin nililinis yun ng hangin.
    Dec 2017
    maiba po ako, may nagsabi kasi samin na kapag mas mababa sa 95 octane, ang ginagamit, mas lalakas daw ang pagvibrate ng makina.. totoo po ba ito? thanks po.
    Dec 2017
    ask ko po kung saan po nakakabili ng air filter? ok lang po ba ung compatible sa honda 2008 ldsi..? ang sabi kasi sa casa, dapat sa casa lang ang mga piyesa.. thanks po ulit.
Non-E10 Gasoline for Honda Civic 1996
