For a few months now, my honda city (medyo old na din kse - 98 or 99 model) has been bothering me with its noisy engine. Sobra ingay (para cya tlgang lumang luma taxi kaingay) specially pag nakatigil lang or nka park na umaandar. Had it checked several times na but naguguluhan ako sa diagnosis nila - valve clearance adjusted several times na pero maingay pa din. Ung mga mekaniko pa, iba iba sinasabi tungkol sa tamang measurements. May shop pa nagsuggest, unahin ko dw timing belt bago ang lahat. Recently, iba na diagnosis - baba na dw dapat makina and piston ring na daw dapat mareplace (di pwede dukutin etc). Mga 2-3 days dw gagawin. Price quotations vary from 5000 to a staggering 10000. Help naman po....don't know what to do and where to have it fixed (na sigurado and d naman msyado mahal)
sorry po...forgot to edit...maingay cya specially pag naka park lang and nka on ung makina.. .need help po kung ano kya tlga problem and solution - iadjust ng iadjust ung valve clearance (hangang makuha ung tama measurements para di na maingay) or replace piston ring etc. San po ba best shop to go (pulido work and reasonably priced)..help naman guys ASAP....:
Im sorry about that. I must admit i'm not really familiar with the posting rules. I dont really post much but im taking the chance anyway because of this nagging problem about the engine noise. I just need help. I hope you can help me.
you can try either forcedspeed or speedyfix. please do a search na lang sa google because i'm too lazy to post directions hehehe.
what is the exact sound? clatter? constant whine? is it really coming from inside the inside, as inside the rocker cover?
constant whine, like a "rrrrrrrrrrrrrr" sound, could just be a broken bearing in the alternator or idler pulley. maybe even a broken tensioner inside the timing belt area.
clattering, like "klak klak klak", is more serious. could be a broken fuel injector, broken valve stem, etc. a lot of shops could properly adjust valve clearances in a honda, but a lot of shops can't either. best to go to a specialist shop like the ones i mentioned. DONT go to freelancer mechanics sa tabi-tabi ng banawe... hindi toyota 3k or 4k yung engine mo.
honda engines are quite sturdy. di basta basta inooverhaul yan unles talagang inabuso. do have the throttle body cleaned, and then do another valve clearance adjust (dirty throttle bodies can also make a weird noise, dont know why. but jeff of forcedspeed cleaned the tb and adjusted something which made the engine quiet again).
The "clak clak clak" sound is more like it. In fact, i think it got even worse after several valve clearance adjustments that were alternately done by different mechanics in our area in Cavite. Sana nga po makuha sa proper adjustment ng valve clearance. Hanapin ko nlng ciguro si Jeff of forcedspeed agad bka makuha nya tamang adjustment and as you said, bka pwedeng linisin lang ung throttle or something. Im worried about the cost if indeed, damaged na nga piston ring and kailangan major repair. Sana wag naman. thanks for the input sir. Ill goggle for directions on how to find forcedspeed right away.
