Page 2 of 2 FirstFirst 12
Results 21 to 34 of 34
    Feb 2009
    bosing baka may major accident nablili mo car, malaki pa ang gagastusin mo dyan.
    Sep 2008
    naku yari ka!! 100k sa transmission? nag cherry kana lang sana 5yrs warranty pa..though hindi ko pinopromote ang cherry against any 2nd hand cars, pero sa case mo you're better off with cherry
    Aug 2005
    try looking for surplus. pero palagay ko, wala pang surplus nyan kasi hindi naman popular. anyway, pwede ka magpa-order sa surplus shop. that's your best bet. or call this number 09193787281. noel ramirez. tell him you were referred by ejay. bring your car to his shop and let him look at the problem. yung shop nya medyo mukang gusgusin. but at times, you will not believe the cars you will find inside the shop.
    Dec 2008
    bro pede cguro i pa machine shop yan dalhin mo sa magaling na mekaniko na sila na ring bahala magpa machine shop magtanung ka......goodluck
    malas naman..parang ang hirap mag drive ng auto knowing na may crack yung transimission. better to get second opinion sa casa , pag confirm, kung ako sa iyo i will sell the car then look for a better second hand car. 100K for a transmission repairs?? estimate pa lang yan.. pero if you plan to keep the car pwede din kaso baka may madiskubre ka na naman hinde maganda at isumpa talaga yung nagbenta sa iyo.
    Quote Originally Posted by athens22 View Post
    Mga sir, patulong naman po.
    Nakabili ako ng second hand na 03 honda city idsi a/t
    57k na yung mileage nya.
    so far, okay naman.
    pero patulong naman po dito:
    1. may crack yung dashboard, san ko pede pagawa?
    2. kapag nag leleft ako, ung steering wheel nya parang naglolock.
    3. minsan may kumakalampag sa harap, sa steering wheel pag malubak,
    san ko pede paayos ung mga kalampag?
    4. ung makina pag matagal ng tumatakbo, parang umiingay na, parang
    hinihingal.
    5. para san po ung tune up? change oil?
    6. san po mga shops na pede ko paayos? ung mura pero magaling?
    7. paayos ng seat belt? kasi pag tumatakbo, may tumutunog sa gilid.
    mga magkano kaya magagastos ko paayos ng lahat?
    salamat po!
    Iyong sa steering wheel parang naglalock . check mo iyong power steering fluid mo baka kulang ang laman at marumi na kailangan palitan . Kung mapula kulay ayos pa iyan .Kung maitim na at brown papalitan mo na.
    I pa check mo suspension mo sa ilalaim baka mayroon ng kailangan palitan .Pagnapalitan na iyong mga sira i pa wheel alighnment at camber kung kailangan.
    Sabi mo second hand mo nakuha sasakyan mas maganda TUNE -UP.
    1. Change oil .Replace with oem oil filter
    2. Power steering fluid.
    3.ATF fluid sa transmission.
    4.change brake fluid
    5. Drain radiator .replace with new distlled water 50/50 mix with coolant.
    6.Check all break pads ,very important
    7 . replaced spark plug.
    8. Replace or clean air filter.
    9.Check spark plug wire set
    10. check engine timing.
    11. Check all hose. Radiator hose for leak.,powersteering hose , brake hose
    12. Disributor cap, rotor
    13.Check all leak . Valve cover gasket., drain oil plug., Crank case gasket and others.
    Note# CHECK MO MUNA LAHAT ITO HINDI NATIN ALAM DOON SA DATING MAY ARI KUNG KAILAN PINALITAN. AT KUNG PAANO NIYA INALAGAAN ANG SASAKYAN.
New car owner HELP!
