Results 1 to 19 of 19
    anung model ang pinaka maganda para i replica SiR???
    thnx mga SIR...
    sir ang dami niyo thread... hehehe
    it depends naman on how you want to use the car.
    for me its still the lxi 2000 para sa FC. same body without the power... kung baga for the daily driven cars.
    Quote Originally Posted by archie123456789 View Post
    haha.. sorry sir..noob lang dito... nararattle na tlga kasi ung isip ko sa pag decide... kinukulit nko ng mga sellers... ndi nmn ako makapag decide..
    Oct 2007
    wag ka magmadali kumuha ng SiR bro, kasi kaw din gagamit niyan baka maka-tsamba ka ng may mga maraming sira, yung kaibigan ko nga last nov niya benenta yung Esi niya para makabili ng SiR hanggang ngayun wala pa siya car.madami na siyang nakikitang SiR na benebenta pero madami sira..take time lang bro at wag ka magmadali kung gusto mo tlaga makahanap ng magandang car!
    Quote Originally Posted by thetabworld View Post
    hmm if thats the case then you should try to test drive all the models para makita mo whats right for you.
    a few hints lang sa problem ng ek...
    yung aircon releases foam like things lalo na kung bagong linis. nakakapuwing kung tamaan ka. hehehe
    solution: full blower mo yung aircon then vacum it out.
    water getting in the sa trunk, pero can be resolved naman DIY lang
    solution: hanapin kung saan nanggagaling then epoxy kung sa may antenna pero kung sa tail light kahit strong tape lang puwde na.
    pangilalim, medyo magastos... lalo na stab link and trailing arm bushing.
    solution: get the replacement (555 brand) na lang mas mura or fabricate (mas tatagal daw)
    slow or stuck up power windows sa likod
    solution: wd40 hehehe
    other than these wala na ko prob sa ek ko... exellent choice of car, for me this is the best model ng civic that came out. good luck sir!
    Dec 2004
    2000 Lxi would be the best. Mas ok kung manual coz you'll never know baka gusto mo mag engine swap madali lang conversion. You wont worry about the interior anymore
    Apr 2004
    vti 99 or 00 na red, black or white.
    tapos stickers...hehe
    suggestions naman on taking the first step to improve my SiR... thanks...
    Sir you are certainly welcome po here sa Tsikot but please refrain from creating a different/new threads with regards to a single topic, your car. You have already created the following:
    http://tsikot.yehey.com/forums/showt...91#post1022291
    http://tsikot.yehey.com/forums/showt...82#post1022282
    http://tsikot.yehey.com/forums/showt...57#post1022157
    It is not necessary for you to create a whole new thread regarding every inquiry.
    Mods I suggest that we merge this.
    if you want to take care of your SiR... the first step is to check all the engine parts... primarily the valve cover gasket then just make sure that you have regular change oil and tune up, usual naman na change ka some parts kasi luma na model... baka water pump timing belt and lahat ng fan belt palit for pms... just check stab link nad trailing arm busing baka may crack na... usual yan sa ek... use the 555 brand para ok.
    Sir archie, tanong ko lang, i have an SIR at pinatignan ko sa CASA, kailangan daw palitan ng trailing arm bushing. saan ba tayo makakuha ng mura neto?Eto yung nasa rear wheel noh? at ano yung 555 brand? sorry just starting to learn about cars palang..
    Feb 2005
    thetabworld - don't create multiple threads. your spamming the boards, which is NOT ALLOWED.
    Quote Originally Posted by drew_5950 View Post
    yup trailing arm is yung sa rear na mahabang bakal...
    naku, dont put your car maintenance sa casa kung wala ka na sa waranty, sobrang taga diyan. if you want to get it cheap lang, yung sa HRC banawe, orig benta nila then may replacements din sila if namamahalan ka. yung 555 brand replacement yun, ok yun kasi ang bilis masira ng orig (in my experience). sulit pa kasi mas mura sa orig.
    pakabit mo na lang motorcraft or m7 which ever is cheaper.
    Dec 2007
    i agree with this. 555 brand is better than federal brand and other 3rd party replacements. Medyo mas mataas nga lang presyo ng konti vs the others. And medyo mahirap nga din hanapin minsan. Sa supplier ko dito sa cainta, madalas out of stock. Pero sulit paghahanap mo or pag-antay ng stock when you get one.
    maraming salamat mga sir.. yung trailing arm bushing, iisa lang ba kailangan or pair na ba yun for both sides sa rear? at saan po ba banda yung HRC sa banawe? malapit lang ba sa M7?
    usually sa trailing arm both yung crack kagad. i would prefer to change both kahit ok pa yung isa kasi hindi na pantay yung wear and tear niya. baka after ilang months palit ka na naman.
    HRC is near banawe corner e rod if your coming from q.ave banawe, straight lang. kung makita mo yung children's medical center lapit ka na. its to your right. if you reach corner ng e rod lagpas ka na.
    heres their contact number 7120303. tanong muna bago punta... hehehe
    good luck sir, its true na scare ang supply ng 555 pero sulit kung makakuha ka.
    sir archie, nakakatawa, lahat ng nilagay mong problem sa ek mo, naging problema ko na din.. share lang. u know ur car well sir.. and i must agree, this is the best civic so far..
    Quote Originally Posted by rye_lara26 View Post
    thanks maam, i love this model of the civic and never intend of selling it... well as of now. kayo din malamang nakaEK civic. just take care of it and it will last for a long time.
    Oct 2007
    Ngayon lang ako napadpad sa Honda Talk ah. Well, anyway, sa TS, an SiR is one of the best cars realeased in the Philippines. Sleek, Fast and roomy (for 4 people) but then Maintenance would be ALMOST the same with the VTi version. Since it's DOHC, Timing belt would be expensive and you have and Idler bearing not like the SOHC engines. Another thing would be fuel consumption. Don't go to the VTEC range because it will drink gas like coke then burp on you like hell. Maintain at power band RPM's and you'll be fine. Also, reagarding the under chassis things, just bring it to someone like cruven or zee. They'll know what to do if you don't have the money to burn on replacements.
    Also an advice would be, dress up the car nicely. Don't go too much on aesthetics as it makes the SiR ricey.
best model for an SiR replica...
