Results 1 to 16 of 16
    Apr 2014
    Mga tsikoters,
    Below are the things I need to fix in my car. Can you provide inputs on what should i fix first kasi low budget ako sa ngaun so ndi pede sabay 2x . I list below that i think i need to fix first.
    1. Rear tire almost worn out
    2. When turning i hear a clicking sound , so i
    i need to fix my cv joint
    3. Power steering kit - as per my mechanic there is a leak that's medyo matigas steering ko.
    4. Repaint my car
    Ang car ko is civic 1997 vti manual. Salamat po!
    Posted via Tsikot Mobile Ap
    Nov 2007
    Quote Originally Posted by Jeff2308 View Post
    Mga tsikoters,
    4. Repaint my car
    I would do the rear tire first. The cv joint and the steering kit can be fixed at the same time if low on budget. Repainting would be last.
    Quote Originally Posted by ans_lim168 View Post
    I would agree. Tyres are the first point of contact between your vehicle and the road. It also might explode and with the rainy season, you are putting yourself at risk with worn out, bald tyres.
    I would always make sure my car is mechanically sound before I put any money into aesthetics.
    Pag ganyan, safety first.
    Aug 2012
    4. Repaint my car
    the order of your list is already correct.
    Apr 2014
    Thanks to all sa mga inputs!
    Jul 2011
    BTW kung almost eorn na rear tyre mo, check mo na din condition and age of other tyres, if more than 3 yrs old better include that in your next maintenance and also the brakes pa check mo
    Aug 2012
    agree. aside from being worn out physically, baka over-age na ibang tires. tire expiration is 6 years. recommended to replace tires in 5-6 years, even if not worn out. check the date code marked on the sidewall.
    If isa lang yung rear tire mo na worn, you also have an alignment (camber/toe) issue.
    Tires first then cv joint. Kung kaya pagsabayin mas maganda.
    Tapos power steering and last is the paint job.
    Oct 2009
    power steering pump was 1.5k repair kit,,
    labor is 300
    Apr 2014
    Quote Originally Posted by jaypee10 View Post
    labor is 300
    Sir saan kau nagpagawa? 3kplus singil sa akin nyan sa zafra motors. And ang labor asa 2k plus . Tnx
    sir, share ko lang yung yung post ko sa HCP baka makatulong:
    Thank you paps for this info and thank you HCP. I went to Ichicar this morning para masolve na leaking issue. Si Bong (owner) mismo naglinis ng PS steering pump ko. I just brought yung Honda PS fluid & repair kit (OEM).
    repair kit (seals & bearing) = P1,274.65 (honda shaw)
    fluid = P550.00 (1L)
    labor = P200.00
    mobile # ni bong c.: 09194016891
    Apr 2014
    Quote Originally Posted by redeemed View Post
    labor = P200.00
    Thanks sir for this info, ask ko lang what address nung ichicar? And yung repair kit seals and bearing sa casa nyo binili? Honda shaw.., salamat!
Need advise - priority to fix first on car (newbie)
