Results 1 to 10 of 22
- Jun 2009
- 44
November 26th, 2009 01:35 PM #1Good day mga sir,
i have this problem on my 96 vti honda,
pag nirev ko yung engine ayos naman yung bigay nung power pero while the "rev" goes down parang nawawalan and nanginginig yung makina para syang mamatay pero hindi sya dumederecho na patay yung makina.
sana matulungan nio po ako,ano po kaya ang problem pag ganito?
Thanks in advance
November 26th, 2009 01:42 PM #2
first thing to do is i-palinis mo ang iacv at throttle body niya. chances are madumi na iyan. if it the malaise still continues baka may kailangan na palitan
you can diy it or go to a reputable shop for that bro
- May 2007
- 104
November 26th, 2009 03:35 PM #3check hcp. andming DIY thread dun. step by step. makakasave ka pa ng pera. pero yung mga ganyan, usual suspects are throttle body and iacv. malaki chances na pag nalinis yung 2 na yun tangal ang problema mo
- Jul 2009
- 6
November 27th, 2009 02:35 PM #4mga boss pa singit same problem skin minsan yun idle drop then nanginginig ng kaunti napalinis ko na din throtttle body and naging okey siya for a while, i observed pag nka a/c lng din ako and biglang accelerate parang hirap humatak and dun nanginginig tapos biglang mawawala yung nginig pag shift nya a/t pla ang akin 97 lxi
- Jun 2009
- 44
November 27th, 2009 06:00 PM #5mga sir update po...
> napalinis ko na TB and iacv...tapos napansin ko parang pag nakaload lahat(a/c,headlight) parang humihina yung headlight(lumalabo) pag tinatapakan ko yung gas then manginginig pero yung takbo ayos naman basta makaandar na yung auto ayos takbo,dun lang po ako nagkakproblema(nanginginig) sa pag andar from a stop.
ano po kaya itong problem na to,ano po dapat palitan?
TIA
November 27th, 2009 06:23 PM #6
Tol paki check mo iyong grounding system .Kadalasan sakit niyan ay hindi magandang ground dahil may edad na rin sasakyan mo . Mag lagay ka ng grounding kit malaki matutulong nito sa pagiging stable ng lighthing system mo at idling.
May mga thread dito na Do it youself grounding kit .
November 27th, 2009 06:33 PM #7
Yung fuel injection na yan bro. Pa-check mo agad. You can try the A&M Shop along Kamuning. Reasonable ang prices nila. Garantisado pa ang trabaho. Sila kasi ang nagpatino sa City at Maxima ko.
- Jun 2009
- 44
November 27th, 2009 07:04 PM #8Sir speedunlimited:
> magkano po ba ang grounding kit?eto po ba yung my volt stabilizer?
Sir jjmd3_787:
> san po yun A&M na shop na ito sa kamuning?my mark point po ba kung paano ko sya makikita?
salamat po sa replies ninyo mga sir
- Jun 2009
- 44
November 28th, 2009 01:02 PM #9Update mga Sir: I had my ECU checked sa Servitek
pinaREAD ko yung sa fuel injection/fuel Line pump,ayos naman daw yung pag bigay ng gasolina,
My question is possible bang okei ang pag deliver ng fuel pero sira na yung pump kaya nagcacause ng panginginig?
- Apr 2009
- 1,902
November 28th, 2009 03:13 PM #10^^Up dun sa grounding kit.
Nagkaganyan na din yung civic ko before, and although it wasnt the grounding kit alone that really helped, mararamdaman mo din naman na worth it siya because mas oks yung electricity delivery kahit on ang accessories.
Yung ganyan problema nung d15b ko nakuha sa injector cleaning, grounding kit at konting DIY adjustment sa menor.
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
