Results 1 to 9 of 9
    HONDA GUROS:
    civic99,SiR body, hindi pantay ang heigt nya medyo mababa ang driver side compare to passenger side. kahit noong stocks pa lahat gamit ko (shocks & springs) ay ganon pa rin... nag replaced na ako ng new lowering spring eibach lowering kit 1.5" drop and also replaced new 4 pcs. KYB shocks and adjustable camber (front only) pero ganon pa rin hindi pantay..
    ano kaya possible parts replacement/adjustment gagawin to make the height even?? PLEASE NEED YOUR INPUTS....TIA
    Dec 2007
    This is normal and no cause for concern. The driver's side is usually the only side that always has weight anyway. It's only natural for that side to sag a little compared to the rest.
    Want to cure it for good? Get adjustable-height coilovers. Then forget about them after you look at the price.
    May 2007
    Change the rubber's located on the shock shaft either they are broken or splayed out. In the latter case, you simply change the rubbers.
    Quote Originally Posted by Type 100 View Post
    Quote Originally Posted by v6dreamer View Post
    thanks i'll check the rubber..
    thanks............
    Dec 2004
    Thats normal.
    I had a 99 sir before and had the same case.
    Just ignore it.
    that is normal. drivers side lean yun. ganun din civic ko dati
    Quote Originally Posted by jaymd View Post
    maraming salamat boss...
    Quote Originally Posted by jundeleon View Post
    Thats normal.
    Just ignore it.
    thanks.................
civic 99, HEIGHT LEVEL PROBLEM
