Results 1 to 9 of 9
- Feb 2008
- 18
May 23rd, 2009 08:19 PM #1HONDA GUROS:
civic99,SiR body, hindi pantay ang heigt nya medyo mababa ang driver side compare to passenger side. kahit noong stocks pa lahat gamit ko (shocks & springs) ay ganon pa rin... nag replaced na ako ng new lowering spring eibach lowering kit 1.5" drop and also replaced new 4 pcs. KYB shocks and adjustable camber (front only) pero ganon pa rin hindi pantay..
ano kaya possible parts replacement/adjustment gagawin to make the height even?? PLEASE NEED YOUR INPUTS....TIA
May 23rd, 2009 11:31 PM #2
This is normal and no cause for concern. The driver's side is usually the only side that always has weight anyway. It's only natural for that side to sag a little compared to the rest.
Want to cure it for good? Get adjustable-height coilovers. Then forget about them after you look at the price.
May 24th, 2009 03:06 AM #3
Change the rubber's located on the shock shaft either they are broken or splayed out. In the latter case, you simply change the rubbers.
- Feb 2008
- 18
- Feb 2008
- 18
May 24th, 2009 11:32 AM #5
- Dec 2004
- 76
May 24th, 2009 01:00 PM #6Thats normal.
I had a 99 sir before and had the same case.
Just ignore it.
- Feb 2008
- 18
- Feb 2008
- 18
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
