Results 1 to 11 of 11
    May 2012
    Hi guys I have a 2009 FD, alignment problem as it shifts to the left. Sent to Value Plus for alignment however they did not proceed kasi daw I have to fix /replace the following issues first
    Rack pinion assembly
    Tie rod end
    Tie rod bar
    Lower arm assembly
    Front shock abs and components
    Questions:
    Reliable ba Value Plus?
    Do I really need to replace these before they can align it?
    How much will it cost me?
    Where best to bring the car (Las Pinas area)
    Thanks
    Quote Originally Posted by Renzokuken View Post
    Tie rod end
    Tie rod bar
    Lower arm assembly
    Questions:
    Thanks
    it is first rule in alignment: make sure your various components are within factory specifications.
    it would be a waste of money, if one were to have his car aligned, with worn suspension parts. the alignment wouldn't hold true after a short time, if it can be aligned in the first place.
    but whether your parts are still ok or not, is another question.
    you can bring your car to another facility, for second opinion. and third opinion, if you so wish.
    if they all say you need to replace some parts first...
    they're probably right.
    good luck.
    May 2012
    good luck.
    Thanks. Will take it to Custoners Cradle siguro
    Any idea around how much it will cost me?
    Any other reliable shops in the south of Metro Manila for the FDs?
    no idea on cost, po.
    toyota kasi ako.
    Aug 2017
    Tie rod end
    Tie rod bar
    Lower arm assembly
    Questions:
    Thanks
    Get a 2nd and 3rd opinion... And prepare your wallet. Rack n Pinion issue is expensive... More so since yours is a Honda.
    Altis' rack and pinion costs P37k (new assembly)
    Good luck
    when i was still active in pre-owned and minana-from-dad car ownership, suspension and steering wear-and-tear evaluation was of the wiggle-it-shake-it method.
    i do not know if this is still the way nowadays.
    but if it still is, one can easily watch and learn.
    Quote Originally Posted by SidCoronel View Post
    Good luck
    Meron sa LVC ₱10k lang yata rack ang pinion assembly for FD. Pero Taiwanade siguro.
    May 2012
    Thanks guys
    Havent brought the car yet for a 2nd opinion but been thinking where to get replacement r&p assembly, just in case
    Other shops/sources I can tap? Appreciate help in advance.
    Jun 2005
    Good luck
    Taiwan replacements cost about 6k sa banawe
    Sent from my MI MAX 2 using Tapatalk
    Quote Originally Posted by sirkosero View Post
    what is their expected relative useful lifetime?
    around 120usd, replace when needed..
Civic FD - Alignment
