Results 1 to 3 of 3
- Jan 2010
- 38
June 12th, 2010 02:30 PM #1is this normal?
1. just this morning before starting my engine, I happened to open my hood and checked my radiator for water.
2. just after i opened the radiator cap, may pressure pa din... although di naman ganun kalakas? is this normal?...I parked my car 8pm last night. diba wala na dapat pressure kasi malamig na makina ko? please enlighten me. thnaks...
- May 2010
- 15
June 17th, 2010 04:39 PM #2
----pre sometimes ung pressure ng radiator anjan lng yan.it happens lng na theres a problem with the coolant that you use (if meron) kasi if you dont know water alone as coolant creates electrolysis is water that can cause mga d inaasahang bagay.. check your coolant, coolant must be -35 to make sure that it is good and will not affect your car.
- Jan 2010
- 38
June 18th, 2010 10:12 AM #3sir naprhel thanks sa reply.di kasi ako gumagamit ng coolant.i frequently used mineral water and so far no overheating encountered yet. just this bubbles nagtataka lang ako kasi wala naman dati. just incase maglalagay ako ng coolant.patulong naman.pano ko ilagay? do i have to drain my radiator or something? please help. thanks...
Xiaomi E-Car
