Results 1 to 3 of 3
    Jun 2008
    mga sir,
    bumababa ang power steering fluid ng civic96 ko, the last maintenance done was overhauling ng power steering pump (pinaayos ko kasi may nararamdaman akong vibration sa steering, nawala n ynug vibration, nawawala n rin ung fluid ngaun hahaha)
    i know there's a leak somewhere...any other ideas you want to share sa mga nakaexperience n.
    salamat po!
    Quote Originally Posted by darkbloodlestat View Post
    mga sir,
    salamat po!
    - Re-fill your PS reservoir when you get home then start the car for simetime while continuously turning the steering wheel from left to right and vice versa. And then in the morning try to look for spots beneath the car. Most probably dun banda yung leak. The hanapin mo na sa taas ng engine hood. Baka may maluwang lang dyan na clamp.
    Jan 2011
    tignan mo yung mga hose na malapit sa reservoir if may leaks sir, usually nagpapa adjust lang mga hose, tignan mo din yung sa baba nang reservoir if may leaks.
power steering fluid bumababa ang level?
