Results 1 to 10 of 31
June 25th, 2011 03:04 PM #1
Tip naman po diyan kung lulusong sa baha especially sa mga kotse at manual transmission.Last thursday kasi,baha na sa araneta.ang dami nag-aalangan lusungin pati ako,e honda civic vti '97 kotse ko.Gusto ko na ibalik kahit magcounter flow nako pero dami din car sa likod ko.Sinundan ko nalang yun mga kotse na lumusong.Awa ng Diyos kinaya naman.Ang alam ko lang kasi paglulusong sa baha lalo na sa manual transmission ay huwag magchange gear.
June 25th, 2011 03:04 PM #2
Patayin din po ang aircon at any other electricals.
DO NOT stop in the middle of the floodwater.
Keep the rev up, to keep water from coming into your exhaust pipe and for other reasons
Kung magchange gear ka, do the heel-toe technique. LOL. Kasi kapag hindi mo ginawa yun, mag-baba ang rpm at ma-vaccum ang tubig. Kaya kung hindi kaya yun, wag na magchange gears.
June 25th, 2011 03:38 PM #3
http://tsikot.com/forums/ford-cars-t...g-101-a-38316/ this thread will help you in your query.
There are a lot of threads about water fording. just read all of them to have a better idea.
June 25th, 2011 03:40 PM #4
ako kapag ganyan ilulusong ko sa baha, I always stuck at the first gear na lang hanggang sa makatawid. Nadala na ako noon, namatayan ako nung nagshift ako in the middle of the flood from 1st to 2nd gear medyo bagito pa kasi ako noon,
June 25th, 2011 03:42 PM #5
Never ever change gear when fording a flood. Low gear na agad pag lusong.
June 25th, 2011 04:07 PM #6
Hindi baleng mabagal ka habang lumulusong sa baha at mataas ang RPM . Kung mabilis ka at maaring mabasa iyong mga electrical wire mo lalo na iyong may mga distributor at high tension wire maaring pumalya makina mo lalo na pag abot na sa Fan ng makina iyong tubig.
- Feb 2010
- 336
June 25th, 2011 04:31 PM #7having experienced what you went through although w/ diesel engine...same as mentioned above w/ additional input just the same underneath components naman be sure after you went thru the floodwater don't turn off the engine for awhile, open the hood for any presence of water if there is specially in carb engines, constant checking of brakes to avoid sudden stuck up and check transmission by changing of gears to also avoid stuck up of clutch lining w/c happened to me last ondoy i traverse half tire flooded street that night for 3 hours before reaching home & the next morning altho i was able to start the engine but the gear won't engage cost me 25k lang naman for that...
June 25th, 2011 06:55 PM #8
Some tips on fording the floods of Metro manila:
1. Make sure your car doesn't have holes on the floor where water could get in. Not only is the resulting mess a pain to clean up, you run the risk of ruining some parts (e.g. rusting of seat rails). Also, as it would be good to have gotten an undercoat just before the rainy season.
2. Check the vehicles in front of you; estimate how high the water would go up against your car.
3. Choose the lowest gear appropriate and stick to it once you're in the water. Proceed at a steady pace, slow enough to avoid splashing water all throughout, but reasonably fast enough to get out of it as soon as possible. don't stop, don't change gears, if driving an M/T, foot off the clutch!
4. Give ample space between you and the car upfront; the last thing you need is having a car die in front of you leaving you no room to maneuver out of its way.
5. Ensure you have an adequate knowledge of the road in front of you. You wouldn't want to be surprised by a big hole.
6. If the vehicle in front of you managed to cross safely, follow its path.
7. When in doubt, don't.
8. After the deed, wash your vehicle as soon as possible, especially the underside.
June 25th, 2011 07:38 PM #10
add:
Remember to lightly press the brake pedal for a while after you have exited the flood. This will aid to remove water from your brakes and let it be ready to stop the car anytime.
If your brakes are wet from the flood, your car will not have the same stopping power as compared to if the brakes are dry.
