Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Mga sir anu po ba possible cause kung bakit mabilis maubos tubig ng radiator?
    Honda Vtec 96 model.
    1.Ok naman yung takip ng radiator
    2.Wala naman akong nakitang leak sa radiator.
    3.Kumukulo yung tubig sa water tank reserve.(parang may pressure yung host papunta sa water tank reserve)
    Thnx
    Malaking possibility na cylinder head gasket or cylinder head itself
    Any idea how much the repair cost?
    1. cylinder head gasket+labor
    2. cylinder head+cylinder head gasket+labor
    thnx
    Nov 2007
    Quote Originally Posted by catseye27 View Post
    Thnx
    Does your ride have a history of overheating? Or did it experienced overheat? If yes then that's the result (loosing water at the radiator tank). I agree with 4gj, check your cylinder head.
    i have a somewhat similar problem though not as bad...yet. i know there's a leak somwhere in my cooling system because every week i have to refill my reservoir w/o hitch, but the thing is i can't pin it down where exactly is the leak. wala naman siyang history ng overheating at kaka-over haul ko lang sa rad niya just before xmas of last year.
    btw, i also have the same ride w/ the TS
    Hindi pa ko ng overheat. nasa middle naman lagi yung temp. gauge.
    Apr 2008
    After you used/park your vehicle.
    Check the upper part of the Radiator.
    If you use Water.
    Mabasa basa sa gilid nya together with the pins.
    May Leak sya somewhere.
    If you use Coolant Mix.
    Sa gilid nya basa-basa with blueish color
    Together with the pins din.
    Usually Dry na dry ang upper part of Radiator.
    Kung Dry naman Upper Part
    1. Check Lower Part of Radiator
    2. Check Hoses
    3. Clips Around the Hoses
    Chief, several things to check:
    1. Thermostat - make sure it operates properly; it opens the valve when operating temp is already reached or exceeded.
    2. Radiator fan switch - Make sure it turns-on the radiator fan to meet the opearting temp.
    3. Radiator fan - make sure it blows or sucks the air that passes the radiator properly. Sometimes worn-out carbon brush and poor lubrication decreases the fan's performance.
    4. Radiator - Rusty and clogged-up radiator fins decreases its performance, resulting to poor cooling system.
    5. Fittings / plugs - leaking or loose cap, rubber hose and other fittings will cause abnornal rise in temp, water loss and poor coolant circulation.
    6. Water pump - defective or worn-out water pump results in poor cooling system.
    7. Others causes as specified by our guru's above.
    Hope these things can help. Thanks!
    To confirm kung yung high pressure comes from cylinder compression or high temperature. Observe the over flow hose after a cold start in the morning. Kung malakas na agad ang pressure while malamig pa ang engine then its probable na gasket or heads problem.
    I think cylinder head/gasket nga ang problema.Any idea how much the repair cost?
    Feb 2009
    thnx
    Had same problem on our starex. Sinusuka nya yung tubig, nag ooverheat. cylinder head gasket nga prob. less than 10k, kasi may mga iba pang nakita na papalitan.
    Dec 2007
    Share ko lang Just to give you an idea. 3.5K Machine shop works + 3K top overhaul labor. Check this thread for more details.
    http://tsikot.yehey.com/forums/showt...t=57429&page=2
    Got it fix now.thnx po mga sir,cylinder head po may problema. almost 15k ang nagastos ko,pinapalitan ko na mga belt.thnx po again.
    i have the same problem right now.
    newly replaced naman radiator ko.
    Jun 2006
    baka butas ang hose
    guys, bago palit na radiator cap ko, pero ganun parin. kahit malamig ang engine kaka on lang, kumukulo agad yung sa reservoir.
    ano prob? yung lip ng radiator?
    Jun 2009
    sir catseye27, bale top overhaul po ginawa sa car nyo noh? san ka po nagpagawa, i have the same problem kc, nagtatapon ang radiator and tumatatas ang temp sa high speed. top overhaul ang recommended ng casa, pero 25k minumum daw. ask ko po sana kung saan kayu nagpagawa at top overhaul po ba ginawa.
    Mga bossing, may ma susugest pobakayu shop na magaling magtop overhaul at a lesser price kesa sa casa
    Quote Originally Posted by rapido View Post
    Buy your own parts and find a competent shop to do the work.
    madali naman po malaman kung cylinder head at high pressure ang cooling system. first, while engine is cool open the radiator cap then start the engine pag bumulwak ang tubig palabas yun na yun lalo na pag malakas ang pagsabog ng tubig. puede rin pag nakalagay ang radiator cap observe nyo lang kung namamaga(bulging) at sobrang tigas ng hose connected to radiator at engine.
Losing water from radiator
