Results 1 to 14 of 14
    Feb 2007
    Mga Sir, patulong po ulet....
    Eto panibagong milagro sa oto ko. Ilang beses na nangyari na pag start sa morning, hindi agad nawawala ang ilaw ng battery indicator sa dashboard then tumataas ang temp gauge up to about 3/4 after about 5 mins. Stationary pa lang ang oto nyan. Hindi pa tumatakbo. Checked if overheat, hindi naman (no boiling and no release of water from rad to expansion tank). Saka kaka-start pa lang so parang mahirap isipin na overheat na agad. Ocassionaly, nangyayari din to pag tumatakbo at lower speed and RPM at less than 1000 (based on my observation). Nawawala ang ilaw ng battery once i revved the engine and then unti unti na rin nag-no-normal ang temp gauge.
    I brought it to the mechanic and unfortunately, hindi nagpakita ang "milagro" na to. Inconsistent talaga ang paglabas. Pag marami-rami na akong napuntahan for the day usually hindi na nagpapakita.
    The radiator has been cleaned just about 2 months ago. The rad cap is new (Federal Mogul). No leak anywhere. Fan is working (malakas pa ang buga ng hangin and nag-o-automatic pa naman) although I'm not sure if it is starting and stopping to run at the right time.
    Dinala ko rin sa battery shop to check and ok pa naman daw ang battery and the one who checked it also told that wala naman daw problema sa wiring.
    I would really appreciate your inputs on this. Thanks in advance.
    pacheck mo alternator ... baka meron nang (intermittent) short sa rotor field coil nya
    running voltage checks may appear normal ... pero sa alternator shop meron sila pang-testing ng rotor, maliban sa resistance check, meron silang inductive test jig
    with the alternator in this condition, the battery is not receiving sufficient charging current ... that sooner or later, battery gets discharged ... sooner if you use your headlights with the aircon
    hth
    Apr 2004
    how's your engine thermostat? baka hindi na maayos umandar nakastuck ng matagal sa closed position... which means na yung tubig sa block hindi umiikot sa radiator causing your temp to shoot up.
    re: the batt indicator light, i think sa alternator yan. baka pudpod na yung carbon brush sa loob, you may opt to have this replaced or just buy a surplus from japan.
    Feb 2007
    Quote Originally Posted by voltscastillo View Post
    sir pano ba malalaman na problematic na ang thermostat?
    Jun 2010
    Quote Originally Posted by manley View Post
    remove mo thermostat saka lagay sa kumukulong tubig, kung nag open good pa ang thermostat.... palitan mo na lang thermoswitch at thermostat saka fan para sure
    Apr 2011
    Good day sir! Nangyari na po sa akin before yan. I was driving a 1995 Mitsu Galant VR V6 then. Ilaw yung battery then temperature to 3/4 pero hindi sya overheat. Sir alternator po problem nyan most likely. Baka nasira na po yung regulator nya. when i had mine checked, sira daw yung regulator pumapalo ng 17 volts yung output ng alternator. I ended up having my alternator replaced. Naging ok na po auto ko after.
    Feb 2007
    Quote Originally Posted by kinyo View Post
    hth
    thank you sir. patingnan ko po alternator.
Battery indicator lits and temp gauge shows almost 3/4
