Results 1 to 16 of 16
    Aug 2006
    I own a pre-owned crv 03 a/t and lately i have been hearing a knocking sound in the hood (engine?) upon start up in the morning ( or when the engine is cold ). The noise persists for a couple of minutes but then disappears when the engine is warmed up na. Had it checked and repaired in Honda Cars Makati - they said the problem was the tensioner bearing and of course I had it replaced by them. But alas, the knocking noise is still there. Can someone please tell me what the problem might be? and a possible solution?
    Thank you in advance for your help.
    Aug 2006
    Btw, read somewhere about somewhere about "piston slaps" on CRV engine and was said to be normal? please enlighten
    Jan 2009
    What type and specifications of fuel and motor oil do you use? Does the engine shake when you hear the knocking?
    Aug 2004
    Could it be the engine mounts rattling around?
    Dec 2007
    +1! Ganyan iyung isang sasakyan namin dati, maluwag na pala sa pagkaka-mount ang engine. When the engine is cold, it vibrates a lot more than when it is hot.
    Jan 2009
    Exactly what I was driving at.
    Aug 2006
    thanks for the replies. I use Petron Touring for my latest oil change, prior to that regular mineral oil. It cant be a loose engine support either otherwise Honda makati would have seen it when they worked on it last week. Its a "takatak noise" and its very audible. It starts when you start the engine in the morning or when you start it after around five hours of being parked. seems like the noise is from inside the engine.
    hope you still have the patience to let me know what u think.
    btw, can i ask a refund from the casa? because clearly what they sold me was not the answer to my problem
    Mar 2005
    adjust the valve clearance.
    Apr 2008
    Quote Originally Posted by Psylocke View Post
    1 point
    engine knocking lalo na kapag naka ilang naka kilometers na ang itinakbo nito kelangan ulit i reset or i restandard ang valve clearance engine mo actually dapat nga every 50k-km dapat ipinapacheck mo na ito kung nasa standard pa rin ang clearance nito para gumanda ang compression.
    pag malala na ang knocking nyan malamang top overhaul na ang gagawin dyan palit valve, vavle spring at valve seals syempre ipapa machine shop mo pa ang cylinder head para ipa-hasa or ipa-grind ang pinaglalapatan ng vavle mo para mas lalong mag improve ang compression ng makina mo kesa sa dati.
    pero sa pagkakasabi ni jgriosa mukhang valve clearance adjustment lang ang kelangang dahil sa ang sabi nya tuwing iistart nya lalo na sa umaga pagmalamig pa ang makina ay nagnaknock ito pero pag mainit na ang nawawala naman na........... kung engine support naman kahit mainit o malamig ang makina mo manginig pa rin ito, di bale makikita mo naman sa mga support or mounts nyan eh kung ang rubber or goma ay wasak na wasak na
    experts, do you think this could be related to oil thickness? or octane rating? AFAIK Petron Touring is 20W-50.
    Aug 2006
    Thank you very much for the advice. will try to have valve adjusted and see what happens. will let you know.
    Dec 2007
    Quote Originally Posted by boy_tino View Post
    I am aware that the TS has discarded the possibility that it is the engine mounting/support that he's hearing when he mentioned the rattling sounds he hears when the engine is relatively much colder.
    I just wanted to reiterate: mas malakas po nang di hamak ang pag-vibrate ng makinang malamig kesa sa makinang mainit.
    My father got to take home several for-sale pre-owned cars in order to quickly find buyers, and we have owned several other vehicles. In my experience, engines vibrate more when they're cold than when they're hot, as evidenced by the vibration of the body of the vehicle -- the colder the engine, the more vibration you'll feel on the body.
    That said, I am not discounting other factors that can be the reason for the "takatak" sound as the TS has mentioned.
    My 2 cents.
    Apr 2008
    jgriosa,
    Is the sounds like tik-tik-tik on the valve cover?Try holding the Valve cover.You could feel the pressure there.If YES.Try checking/Repairing the VALVE-Rocker Arms.
    You could change 8PCS or the whole 16PCS.
    (not sure on total quantity of rocker arms on a GEN2)
    It looks like this #2 & #3
    Around P200 per/pc
    Apr 2008
    Quote Originally Posted by jgriosa View Post
    Piston slap sound is not normal i guess.
    Specially kung malakas na sobra like dinig mo inside the car.
    For sure if this sound continues the Camshaft will be damaged.
    Specially if u use lower viscosity of Engine Oil.
    Use 5W40 on your CRV bro.
    P2000+ sa CASA.
    Good for 6 months.
    Aug 2006
    returned my crv to honda makati this morning. i hve let the leadman hear the noise. he said that 70% sure that its piston slap. he suggested that let the vehicle stay with them for a while. the takatak noise is really loud that you will hear it inside vehicle even when window is closed.
    the noise lasted not more than a minute after the initial start-up .
    bro, are you using 93 octane? does the knocking occur with 95 octane? this particular model specifies 95 octane gas.
    also, as Onyl Ryan said, 5W-40 would be more suitable for your engine.
Knocking Noise when engine is cold - CRV 2003 Pls. Help
