Results 1 to 6 of 6
    Aug 2008
    guys i need help saan pwede maka buy nang knock sensor sa b16a ef engine?kc un bnasa un ecu lumabas na i need to replace the knock sensor...are all knock sensor the same para sa b16a ef and b16a eg and un b16 nang sir..pwede ba kahit anong knock sensor basta sa b16a lang? and saan pwede mag pa rewire sa engine to ecu na nice at hindi masyadong mahal ?
    thanx fot the help
    Aug 2005
    Quote Originally Posted by joshi View Post
    thanx fot the help
    basta b16 pwede. surplus is your best bet.
    Aug 2008
    kung mag indicate un cel23 (knock sensor) sa ecu,ano dapat gawin?sensor problem ba?or timing prob? dapat ba palitan un sensor ?ni reset na namin un ecu
    Aug 2008
    guys whats the next step the fault code 23 (knock sensor)keeps on flashing?what should i check 1st ?is it a faulty sensor?or a wireing problem on the sensor?anong shop ang magaling sa mga ganito na prob?
    ty for your reply
    Feb 2011
    pag ganyan check mo bka walang KS or lifted ung nakakabit na wire sa KS
    Aug 2010
    Taga san ka sir,dalhin mo dito sa Salitran kay Mel Casaba.Ganyan pinagawa ko
    sa kanya,knock sensor din problem ko dati.Nagpalit kami then up to now ok na.Dati kasi di ako makatakbo ng 80kph right now nakaka 100+kph nako without knock sensor litting.Magaling yun magbasa ng error codes.
knock sensor nang b16a engine
