Page 1 of 2 12 LastLast
Results 1 to 20 of 31
    Sep 2008
    May mga nag swap na ba sa inyo ng K20 sa EG body? Tanong ko lang kung meron kayo idea kung mag kano aabutin sa swap at mga parts (mounting kit, shifter cables, support brackets, labor etc). Tanong ko na din sa mga nag swap kung maayos nila nagagamit yung auto nila, kung meron ba problema sa clearance ng makina sa lupa o sa hood.
    Salamat
    Apr 2004
    Quote Originally Posted by BatangSaudi View Post
    Salamat
    pwede ba? kasi alam ko sa EK medyo tatama sa hood yung power steering pulley (although it's been done na). do check hondatech, may mga articles dun. sa EG, it could be an even worse fit.
    best engine swap option is still the b-series. even the crv's b20 could fit into the EK/EG.
    k20 will fit into a ES, though. odd.
    brader ok ka lang?
    B series at D series lang ata ang kakaysa sa engine compartment ng EG. Ang Kseries nga sikip na sa engine compartment ng FD eh.
    Ang K series pwede sa: Pero depende sa displacement yan ha
    ES
    FD
    CR-V 2nd and 3rd gen
    Accord present gen and yung mga 2004 model
    GD
    GE
    City (old yung mukang ipis)
    City (new)
    its been done, ive seen some EGs sa clark on k20 engines. never witness shops clamping the engine though. as for the cost, not much idea pero definitely doable.
    Dec 2003
    If you are going for a k series swap in EG its been done here.Best engine mount for me is the ekk2 hasport engine mount.
    It will cost you a lot for a kseries swap.
    Sep 2008
    Quote Originally Posted by gearspeed View Post
    Hasport lang talaga ang alam ko na mounts. Wala ako idea kung meron binebenta nito dito kung o kung magkano. Most likely order sa labas.
    Ang alam ko ang makina around 200k (K20a galing sa integra dc5). If im gonna spend a 100k more well and good. I like my eg though k20 has a lot of potential and there are heaps of people that have b-series under their hoods.
    Aug 2005
    the swap is very possible. even if you don't use hasport conversion mounts, shops can fabricate it here. anyway, you might want to consider the hp/peso value of your plan. with the amount of money you will spend on k20 swap without mods, it would be more cost efficient to get a b16b and slap on a turbo kit. it would be cheaper and possibly make 50% more power than a moded k20 engine.
    Feb 2007
    Visit HCP pare, meron nang mga naka k20 na EG dun. If money is not a problem, the best talaga k20a lalo sa eg kc magaan. Instant 13 sec. car plus the bling factor pagtaas mo ng hood. Pero in terms of money spent per HP nabasa ko sa H-T na mas lamang ang b18c. Pwede ka pa mag aircon at ps.
    nothing is impossible...
    Jun 2008
    aba kita mo nga naman... David has Goliath's heart
    Dec 2003
    Hasport lang talaga ang alam ko na mounts. Wala ako idea kung meron binebenta nito dito kung o kung magkano. Most likely order sa labas..
    Hasport here cost around 40,000 pesos in h3 if you convert it into dollars its already 860 dollars.Better buy it straight in the U.S.
    I almost forgot innovative mounts pwede rin.
    Apr 2009
    k20 eg and ek
    Apr 2004
    ganda. looks absolutely massive inside the engine bays .
    i guess oras at pera lang ang katapat nyan.
    brader ok ka lang?
    ES
    FD
    GD
    GE
    City (new)
    Pwede naman pala e brader...
    Dec 2003
    Pwede pa nga k24 dyan sa EG eh.Meron pa nga J swap eh.
    May 2009
    Pwede kaso dito sa pinas hindi pwede yan,wala aircon maiinit engine pa lang ubos na pwesto para sa aircon mo.
    Jun 2006
    Kinda reminds of the LS2 Miata.
    Sep 2009
    You can easily do the swap if u have at least 700,000 peso...
    U need to get the following:
    Hasport or Karcept engine mount, conversion harness, shifter, headers, fuel injectors, fuel pressure gauge, and etc which will be from the US..
    You can still have the luxury of AC but u need to by the conversion kit from Hasport and get a 96 civic condenser and if u need PS u can also do that...
    If u got the funds nothing is impossible... Other's will say slap on a Bseries but its a different feeling....
    Let me know if u need all the parts..
    Dec 2003
    May nakita ako before fabricated mount lang kaso tabingi ang kinalabasan dun sa k20a niya.
    Aug 2005
    700K. big bucks! i will sugget though to know what you want first before spending that amount of money. you can get the same amount of performance from other engines spending significantly less.
K20 Swap sa EG
