Results 1 to 17 of 17
    Oct 2009
    mga boss tulong naman sa auto koh esi pag inistart koh sya ung rpm nya papalo ng mataas pagkatpoz babagsak ng mababang mababa tapos para ciang palyado pinatingnan ko na ung trottle body malinis pa naman daw...anu kaya diprensya na 2 mga boss iritang irita na kc koh sa tunog nya palyado nakamuffler pa nmn kya dinig na dinig....tulong nmn mga boss...gus2 ko na masolusyunan un dilema ko na to....tia!!!
    Apr 2008
    boss,
    try mu to... ipa check mu yun injector baka madumi... at yun iacv mu...pinapalitan mu na ng sparkplug?
    Jun 2009
    Is your car fuel injected, what brand/ model? Suggest you bring your car to a shop equipped with proper scan tool, to eliminate the usual trial and error method practiced by backyard mechanics.
    [SIZE="4"]Reminder: do not post messages in SMS/TXT format.
    READ the RULES.
    [/SIZE]
    Causes Dirty Mass air flow Sensor, Idle Air Control Valve. Need to be clean . If its already clean you will notice that the rpm will go high and have the mechanic to check your engine timing to engine specification by using a Timing gun not by trial and error and adjust the right engine idling.
    Oct 2009
    efi na poh ung car honda esi
    Oct 2009
    to edge......pwede din kya sa valve diprencia nun?sige try koh din palitan ...how much po ba ang 1 set kaya nun?
    speed's opinion is correct. i have experienced it also the past few weeks. sama ng idling, sama ng acceleration. when i had it cleaned yesterday, ganda na ng takbo.
    hindi nakikita ng silip silip lang kung madumi ang TB on hindi. dapat kasi nililinis ang lahat, including the sensors where much of the dirt are stored.
rpm bumabagsak parang palyado
