Results 1 to 5 of 5
- Jan 2009
- 16
January 25th, 2009 04:15 AM #1mga sir ilang cc ang stock engine ng honda hatch at advisable bang bumili ng stock o mas maganda yung upgrade na yung engine para malakas? mgkano po ang estimated price ng upgade engine compae a stock. nakita ko ksi sa adds na mas mataas ang price nung ngpalit na ng engine. thanks
January 25th, 2009 06:05 PM #2
1200cc. You can upgrade, but only if you want more power. As to whether to buy a car that has had an engine swap... it will depend on the quality of the swap... if the wiring was poorly done, then it's often better to just buy a stock car and do the work yourself.
January 27th, 2009 11:31 PM #3
bumili ka na lang na changed engine na kung may budget lang din.. wala ng ilalakas ang stock 1200 na engine ng hatchback.. carb type po yan at hindi EFI.. kung magpapalit ka ng engine it would cost you around 35k all the way to hundreds of thousands.. depends on the engine na ipapalit mo. Marami naman nag bebenta ng naka B16 o naka D15 engine sa market.. Hanap ka nalang ng medyo sariwa pa, wala ka pang sakit ng ulo.. Kung hindi ka naman kumakarera.. stick with the 1200, tipid!
- Jan 2009
- 16
January 28th, 2009 03:05 AM #4thank you sir sa advise, plan ko ksi bumili ng hatch, ung medyo may power at less sakit ng ulo sa sira.ano ba yung diference ng EK sa EG, same model ba yun ng hatch.
January 30th, 2009 12:53 AM #5
Body type ang eg tsaka ek sir, meron din ef.. yung mga medyo may kanto ang body.. kung hindi ako nagkakamali eg is from 91-95 yr model (mga ESI), and ek is 96-2001(VTi ,SIR) EK 1 2 3 4 pa.. (paki correct na lang po sa iba kung mali ako)
Palagay ko Eg yung hinahanap mong hatch.. kase yun ang marami sa market.. Para po sa akin eh astig ang hatchback noon at ngayon. Maganda sa hatch kahit ibenta mo ulit mataas paren ang resale value..
karamihan ng hatch na EK lumalabas sa Pinas ay imported at matic.. Hindi po inilabas sa casa.
Drive Safe Chief!
high idle RPM at engine start
