Results 1 to 15 of 15
    Jul 2012
    Mga sir, ask ko lang when po dapat palitan ignition coils. I drive a honda jazz GD3 VTEC po. lately kapag nka idle po sya lakas vibration.. mas matindi vibration kapag nka aircon. kapag nag gas nko mejo ok na pero if accelerate nko yung nanginginig ulit. nabasa ko po ito: 6 Symptoms of Ignition Coil Failure | DoItYourself.com
    ano sa tingin nyo mga sir?
    Oct 2013
    Quote Originally Posted by nashimoto View Post
    engine/tranny support muna.... may check engine light/error ang ignition coil/misfire...
    Feb 2009
    Stop guessing
    Jul 2012
    car was checked by my suking mekanik.. ignition coils nga..
    Jul 2012
    mga sir anu po ma recommedn nyo ignition coils? sabi nila yung circuit brand hindi raw maganda, so far yung ata pinaka mura - nsa 1.5k lang. may tag 2.2k IKI ata brand. ok ba yun? mahal kasi ng honda nsa 4k+ isa.
    Baka naman hindi lahat need palitan?
    Jan 2011
    subukan mo munang manghiram ng coil sa shop ng mekaniko mo. use it for a day. pag ok ang takbo ng car, tama ang diagnosis niya. youve got to be sure, daming factors ng car vibrations. hope this helps.
    Jul 2012
    may cracks na po yung 4 na ignition coils ko.. when i pulled them out and check every one of them may crack dun sa body mismo. i cleaned the contacts and put electric tape on the crack to seal them. binalik ko sa makina and the jerking was gone, hindi na rin bumaba yung rpm kahit nka idle.
    Jul 2012
    also since I will be replacing coils.. naisip ko buy new spark plugs narin. what can you recommend na mura.. plan ko nmn regularly mgpalit ng sparks para good maintenance na rin.
    4 ignition coils?
    Nalito ako, 4 ignition coil meron car mo? Hindi kaya what you mean is 4 spark-plug wires? Korek me, kung mali lang ako.
    Sent from my Starmobile UP+ using Tapatalk
    Aug 2004
    Coil on plug most likely if distributorless. One coil per plug.
    Oct 2014
    Ganyan naging sakit ng jazz ko matic 2006 model. Ignition coil ang naging problem, ng pinalitan na yong apat umokey na. Try mo tawagin ito, dati sya tiga honda, supplier sya ng mga parts, sa kanya ko kinuha ignition coil ko. Name nya Frank. 09195040363 or 092662800788
    Apr 2016
    Sir. ASK Lang po MagKano IKI Ignition Coil sa Banawe?
    Jul 2012
    Quote Originally Posted by KHM View Post
    for sure mas mura.. 2.1k sa alabang parts eh.. i suggest buy the orig bro.. min lasted for 1 year. ayun nka surplus ako ngaun.. pero will be buying orig ign coils.. ipon mode muna.
    Jul 2012
    Quote Originally Posted by rene capuno View Post
    sir ok pa ba itong numbers na to?
ignition coils
