Results 1 to 6 of 6
- Sep 2009
- 1
September 8th, 2009 09:34 PM #1need help!!!!kc may problema me sa idling bumabagsak kc hangang sa mamatay na oto ko pero napatune up ko n sya napalitan kona ng spark plug saka napaoverhaul ko na ung carburator ko!ano pa kaya ang posible cause bakit ngk2ganon .sk magkano kya carburator na surplus?
September 8th, 2009 10:49 PM #2
September 9th, 2009 11:38 AM #3
i have a 94 accord exi. mejo kinakabahan lang ako kasi bumababa yung masyado yung idle (zero) kapag nagdodown shift ako... bakit kaya?
- Sep 2009
- 4
September 9th, 2009 05:04 PM #4ser, nagbabago b ung menor pag tumatakbo na? hard starting b? try mo p tune up auto mo sa Kamuning, dun ako galing last week, ayos n auto ko after ma tune up.
September 9th, 2009 05:27 PM #5
Avoid using TXT/SMS format here in Tsikot Forums. It is PROHIBITED
Thanks.
- Sep 2009
- 9
September 16th, 2009 07:32 PM #6Boss,
Nabasa ko to sa isang forum. Pag erratic idling daw minsan madumi lang yung iacv, servo or throttle head. Yung iba pag kalinis nun naging ok na after. Try mo lang sir baka maging ok
high idle RPM at engine start
