Results 1 to 13 of 13
    May 2007
    sirs, lately nag kaka problema aircon ko saka RPM. pag pumalo RPM ko sa 2k biglang nawawala lamig ng aircon. pag pinatay ko naman yung AC via AC button babagsak yung RPM to 1k. pag on ko ulit palo ulit sa 2k yung RPM pero walang lamig yung aircon
    pag tumaas RPM at nawala lamig ng aircon ginagawa ko papatayin ko muna yung AC via AC button pero bukas pa fan tapos try ko ulit after ilang minutes. minsan lumalamig ulit aircon madalas hindi. pag naka pag pahinga na ulit kotse pag unang bukas ng aircon malamig na ulit, pero pag tumaas ulit RPM ko to 2k mawawala na naman yung lamig ng aircon
    ano kaya problem? nung nag pa service kse ako sa honda greenbelt tapos sinabi ko yung problem ng aircon sabi sa akin baka daw aircon compressor yung problem. pero hindi pa ako nag papa check ng compressor. alam ko na kse sasabihin ng honda "sir palit na ho tayo ng compressor". gusto ko muna humingi ng opinion dito bago ako bumalik sa honda
    haba sorry hehe
    TIA
    Aug 2009
    Try to go to Mang Mario at his residence in Bago Bantay Quezon City. There's a thread here already about him, his expertise in car aircon and his exact address.
    My 2004 Honda City Idsi had a similar problem last year. Nawawala ang lamig after running the car after some time. I went to his residence and told him my problem and right away he knew what the problem is. He asked one of his boys to look at my aircon. In less than 30 minutes, the problem was solved. The guy just reduced one thin small piec of washer of the compressor clutch which, according to Mang Mario, disengages easily as the unit becomes old, hence, the compressor won't work. And he just charged me P100 for that. My aircon functions perfectly well until now.
    baka barado na valve,,same ng prob ng corolla ko biglang nawawala lamig off ko lang ang aircon after 5mins on ko uli malamig na siya ulit...kada lalabas yun sakit niya yun lang ginagawa ko pinalinis ko aircon palit ng valve kasi barado di na siya maihipan pagbili ko ng bagong valve swabe ihipan nagpalit na din ako ng dryer yun after nagawa di na nawawala lamig
    sana makatulong
    Dec 2007
    Been there experienced that.
    Have your A/C system cleaned and have the compressor clutch looked at. The magnetic clutch isn't engaging - that's why you have loss of cooling and the high idling problem.
    An A/C technician can remove some of the spacers so that the clutch engages better. I've practically removed all the spacers on my compressor, so if this problem happens again I'll probably be looking at a brand-new compressor.
    HTH
    May 2007
    *daddycool
    nung nawawala ba lamig ng kotse mo tumataas idling mo? sa akin kse tataas muna idling to 2k tapos biglang mawawala lamig ng aircon
    *adapilado
    sa akin kse minsan pag off / on ko ayaw pa din lumamig. kahit after 20min ayaw pa din minsan
    *Type 100
    yan din sinabi nung taga honda sa akin. compressor na kaya talaga problem? mahal pa naman ng compressor. 5 years pa lang kotse namin, ganun lang ba talaga buhay ng compressor mga 5 years lang?
    may nabasa ako dito sa honda cars talk regarding high idling and low cool aircon. MAF sensor and servo naman daw. same lang din kaya ng problem yun?
    may alam ba kayo within makati na magaling mag check ng aircon?
    thanks sa mga reply guys
    Dec 2007
    Quote Originally Posted by eido View Post
    *Type 100
    Trust me it's the same thing. Your City and my Jazz are mechanical twins. Try to have the compressor spacers removed and see what happens - it's a very cheap fix. Dukot lang yan.
    Compressor lifespan depends on the technology used. There are at least two types - one is more robust but has more parasitic loss from the engine; the other is more economical but when it goes kaput you need to replace it. I'm not sure which one is ours.
Honda City 1.3S 04 MT aircon / RPM problem
