Results 1 to 17 of 17
    Sep 2010
    Hello everyone
    I just got a used 2010 Honda City 1.3 automatic with 45k on the odometer. When I checked the spare tire, there was about 2 liters of water under the spare tire. The rest of the trunk was dry, even the spare tire compartment cover, carpet, and trunk sidings were all dry.
    I thought that maybe the previous user drove it through flood so I just cleaned it. But in the past week from October 20-26 with very little rain in Metro Manila and no floods, there was again about 500ml of water under the spare tire.
    Any ideas?
    Thanks
    FS
    Check the drain plug of the trunk.
    Mar 2012
    Did a lot of googling on this as I have the same problem. Possibilities: worn-out gaskets of either trunk lid, tail light or rear glass. Best way to find out: somebody check inside the trunk with a flashlight while somebody hoses from outside. Now I just have to figure out how to remove the inner liners so that I could see where it trickles.
    Sep 2010
    Thanks for your suggestions and input
    FS
    Sep 2012
    Try mo baklasin yung mga plastic cover parts ng trunk mo usually naka clip lang ito para ma isolate mo kung may makikita ka na butas
    And as stated sa taas hanapin mo yung drain plug nyan usually its a black round rubber na nasa area lang din ng spare tire mo.
    Apr 2013
    nangyari sa akin dati ito...driving an old 94 lancer, kapag umulan ng malakas sigurado may laman yung trunk, same din sa iyo sa lalagyan ng spare. di ko alam dati, while driving, para akong may dalang aquarium at tuwing pepreno at aandar e parang alon sa dalampasigan sa loob ng car.
    Take out everything from the trunk. Put dry rags all over. Garden hose the trunk and back fender. Dry the exterior, open trunk and see which rags got most damped. Then just resolve the issue.
    Sep 2012
    Quote Originally Posted by Lew_Alcindor View Post
    My bet is on leaking tail light gasket.
    Yung trunk kasi mejo may grooves yung edges so kahit sira weather strip, yung groove mag-guide sa tubig pababa at palabas.
    Possible din ito... sa ibang sasakyan dati na experience ko sa garnish naman lumusot... may maliit na crack pala na hindi basta napapansin.
    Kamusta TS nakita mo na ba cause ng trunk flooding mo?
    Mar 2012
    Thanks for this Sir Archie, ito nga pinaka practical, para may idea ako kung saan banda ang leak galing. Baka no need to baklas all the liners. Mahirap lang pag tail light gaskets nga, nakita ko kasi sa youtube na kailangan baklas ang bumper para tanggalin ang tail light. Kailangan talaga dalhin sa body repair shop.
    Quote Originally Posted by [archie] View Post
    Sep 2010
    Sorry double post
    FS
    Sep 2010
    Thanks for all your input. Car never had an accident. Haven't had the time to work on the problem.
    I will try removing the sidings and line the trunk with newspaper and see what happens when I hose it down.
    FS
    Mar 2012
    Sir Frontsight, share mo dito kung pano mo binaklas ang sidings and how it went ha. I also want to remove mine with the help of your hindsight.
    Same problem tayo TS, 2009 city may tubig din sa ilalim ng spare tire, kulay kalawang pero wala namang amoy.
    Sent from my GT-N7100 using Tapatalk 4
Help!  Water in under spare tire of 2010 City
