Results 1 to 9 of 9
- Feb 2009
- 15
February 25th, 2009 02:10 PM #1start yung problem ko nung ginamit ko aircon ko from manila to nova qc. pag dating ko mindanao ave namamatayan n yung car hrap n mag start mga 5 times yun ng yari, but still n nka rating p rin ako nga nova. then i open my hood my singaw doon s reserve water at yung radiator ubos n water. nag punta ako ng evanghelista.
*pinachek ko yung fan ko kase pag ng on ako ng aircon di sya umaandar so ngayn ok sya ummandar n fan ko.
*after a week nag mall ako ng 12pm frm paco to moa i used aircon pag dating ko moa i park then chek the hood when i open ayun ulit, yung lagayan ng reserve water doon sumisingaw yung evaporate n water. yung fan ng radiator ok nmn gumagana at yung fan ng aircon. so when i chek yung ilalim wla nmn leak. when i chek yung radiator ko gumagana nmn.
ask k lng po normal b yung water s radiator yung takbo nya medyo mabagal pg nka on yung makina then pag ng rev ka medyo bibilis ng konti.?
paano po ba malaman kung yung sira is yung water pump ko.
and if kung meron kyo kung saan k pwede pagawa itong auto.
- Aug 2005
- 205
February 26th, 2009 04:16 AM #4
You had bad Radiator Cap. While engine is cold, fill radiator with 50/50 coolant and use a new radiator cap rated at 13 lbs w/ max of 16 lbs. Then fill reservoir to cold line on reservoir. Without testing for other issues, I believe this should alleviate your troubles.
- Feb 2009
- 3
February 26th, 2009 02:55 PM #5ask k lng po normal b yung water s radiator yung takbo nya medyo mabagal pg nka on yung makina then pag ng rev ka medyo bibilis ng konti.?
normal yun and your water pump is working based on your observation.. check mo yung ibabaw ng radiator kung may natuyong tubig . doon minsan dumadaan at nag iivaporate yung tubig ng radiator pag may singaw na yung gilid ng radiator mo.
- Nov 2007
- 2
February 26th, 2009 06:10 PM #6Get your water pump and radiator checked... this should solve the issue... and make sure you use a coolant after they clean your radiator..this helps the engine a lot.
- Feb 2009
- 15
March 2nd, 2009 08:45 AM #7mga Sir salamat s inyo. this sunday nag hnap ako ng mg aayos ng problem s pag overheat. and this time ang dami k n, n pg tanungan pati s mga casa. at s mga talyer, then ang dami comment s casa palitan k raw buoong radiator ko pati fan & condenser and conderser fan kase sobra laki raw ng condenser tinakpan kalahati ng radiator ko. balik ko raw s stndard setup. then nag punta ako s aircon specialist then sinabi ko s kanya yung encounter problem ko pag nag aircon ako ng matagal. he chek my aircon ok nmn raw. then yung radiator ko sinilip nya then put accelerate nya ayun umaapaw sabi nya palinis k raw muna. so ayun nag palinis ako radiator 700 lng then tess nila for 40 minute nka andar yung car ok nmn d n tumataas temp ko. and also pinalitan nya cover ng radiator ko. d raw match.
this sunday ng biyahe ako frm moa to nova aircon is on never ako nag overheat. temp gauge d man lng kumalahati.
tanx s mga opinion nyo and lucky lng ako di ko agad pinagawa s casa yung kotse it almost cost me 8k s casa.
overhual radiator caost me 700 pesos.
marami salmat.
March 2nd, 2009 09:24 AM #8
galing nung nagsabi ng radiator cap... san ka nagpa overhaul radiator mo?
- Feb 2009
- 15
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
