Results 1 to 1 of 1
- Mar 2013
- 139
June 15th, 2016 08:19 PM #1The drawbacks of water based paint:
First: Water borne paints are softer than acrylic oil based paints. The quick forced dry process using higher curing temperatures causes the paint to dry fast, but not as hard. As a result, these paints scratch more easily.
Second: Water borne paints also have difficulties with increased orange peel and production line runs and sags. The increased orange peel causes a reduction in overall smoothness and gloss.
Third: Water borne paints are also more porous than conventional acrylic finishes. This accelerates a process known as drift. Drift is the process of waxes and sealants soaking into the pores of the finish. Because the finish of a painted surface looks similar to the surface of the moon, peaks and valleys etc., as sealants heat and cool, they soak into the finish. Drift occurs in every known finish, however the water borne paint allows this process to occur much more rapidly, in some cases, even as short as a two week period of time. As drift occurs, the paint is left susceptible to the outdoor elements. This leads the paint to loose gloss and be susceptible to water spots, acid rain, industrial fallout and many other forms of foreign particles.
so wax & protect your car as often as you would.
Daming issue ng SU7:grin:
Xiaomi E-Car
