Results 1 to 1 of 1
September 13th, 2017 08:45 PM #1
in the process of fixing a honda city ph13 engine with the carb fuel system.
interference ba or non-interference ba itong makinang ito?
sinubukan ko kasi ikutin at a very slow pace kung magbabanggaan ang piston and valves kaso wala ako nadamang resistance. o baka naman putol na crankshaft. nakow wag naman.
naputulan kasi ng timing belt. was trying to fix initially a no spark condition. tapos later on napagalaman ko na putol pala t-belt.
on the ignition problem, i measured 0.6 ohms on the ignition primary circuit & about 18 kiloohm on the coil secondary ciruit. test light did not flicker on the positive and negative terminals of the ignition coil. so i therefore conclude na igniter/ignition module ang may problem. so ayun nabaklas ko na buong distributor...will also replace the distributor oil seal and o-ring.
saka ko lang nalaman na putol ang timing belt nung papalitan ko na spark plug hole oil seals.
salamat sa sinumang makakapagbigay ng info.
Hello po, new lang po me sa Car Industry Me and my Dad purchased a 2nd hand po na toyota innova...
