guys, kailangang ko uli ng expertise nyo. ano ang pros and cons of buying a Honda civic vti 2002 model (or vti- s depende kung kaya ng budget). ok ba talaga sya? how about ung gas consumption? thank uli sa inyo!!
Hey! This is exactly my car! But mine's not for sale yet!
I get 10.5 km/l on petron extra unleaded and 31 psi tires. I have 57 thou on the odo. No kalawang of any sort yet. Pero nung bago pa lang, nagpalit siya on warranty ng front suspension at nung gas tank strap thingy. I get great acceleration and speed that I'm not even tempted to race anyone. The a/c is still very cool and though the nvh has deteriorated somewhat, I'ver had worse.
I hope that helps. More importantly, bring a good mechanic and find out if the car's condition is still good -- mas relevant yata yun kesa sa rep ng car (unless you're buying mine but it's not for sale yet!).
[quote=pup2;769371]Hey! This is exactly my car! But mine's not for sale yet!
10.5 km/l? wow, i was only expecting 7-8 km/l. salamat po!
I own a 2001 1.5L model and my main gripe is the soft rear suspension (had to change to KYB gas shocks). I had problems with the engine shutting down but it was traced to a defective sensor (i put up a topic on the maintainance forum for this).
Fuel consumption i get in the city (1.5L m/t) is around 11km/L... if i get into bad traffic or drive a bit hard then it goes down to 9. On the highway with easy driving i do 14, with hard driving it goes to around 11. I'd expect the VTi to do a range of around 8-12 depending on the road conditions.
For a while my engine vibration got bad but it turned out to be a busted motor mount. Parts arent a problem and space is also good for a car of it's age. My suspension was already fixed to a kalampag free state (at Cruven); i find the a/c weak as compared to the ones in our Nissans and Toyotas before.
Of all the civics, 7th gen ang may pinakamaraming deffect, mainly the following:
Front compliance bushing
Front shocks
Front srpings
TDC sensor (ito yung cause ng bigla namamatay makina)
headlight switch
ECU (needs reflashing to an upgraded version)
Fuel tank band
Aircon Power transistor (Yung nag cocontrol ng aircon blower speed)
engine support
throttle body (ito yung cause ng common idle dropping)
Front brake pads
Lahat yan pag nireklamo mo sa casa while the car is with in warranty papalitan nila. Yun lang ang hassel, balik ng balik sa casa.
I suggest kung bibili ka ng 7th gen check mo yung maintenance history kung nag comply na sa lahat ng mga recall na yan. Just get the plate number then run it sa system ng honda (dapat may kilala kang service advisopr para libre :d )
Once those deffects have been rectified, wala ka na sakit ng ulo.
My car, 2001 model is one of the first cars na lumabas ng planta. My car happen to have all those deffects mentioned above! :D But thanks to HCP and CSG, nalaman ko yung mga common problems ng 7th gen and so I had this fixed before mag expire ang warranty ko.
My car, now 6 years old still gets 8 to 9 kms/L city driving. Not bad for a 1.6L a/t. Mas mabilis siya mag accelerate kaysa altis a/t and other 1600cc a/t cars. The car is very roomy! Yuna ng sinasabi parati ng mga nakakasakay sa oto ko, ang luwag daw! the rear has a flat floor and kahit isagad mo yung driver's seat paatras you still have around 8 inches of space in between the rear seat.
Aircon is OK. wala tint oto ko and still comfortable kahit tanghali.
Topspeed i got was 200 kph * 6500 rpm. I did this sa NLEX.
Brakes is not so good for the 01-02 pero yung 03 VTis up naka rear disc brakes na so mas malakas ang brakes.
Yung sa akin yun lang front suspension thingy tsaka fuel band! Dami naman niyan?Baka sa automatic version lang yan kaya? Yung amin kasi 2001 and 2002 civic na manual parehong yung suspension at fuel band lang pinagawa -- yung fuel band sila pa nag-recall.
