Results 1 to 7 of 7
    Feb 2009
    Hi guys...
    Help naman po hingi lang po ako idea para makakuha ng maganda at maaus 2nd hand na honda lxi 99. Ano ba yung mga dapat echeck...
    Thank's po
    ^^ check ka sa tsikot classifieds. pero as always, inspect the car thoroughly, do a test drive and check the papers if they are in order.
    Nov 2007
    Quote Originally Posted by 1D4LV View Post
    yes test drive importante yun.. bring a tursted mechanic usual SOP yan for second hand...tas yung papers importante na maayos at kung maiiwasan dapat hindi encumbered sakit sa ulo pag nagkaton...
    wag magmadali always wait for the best options... HTH
    Feb 2009
    Salamat sa reply...
    Pero sa honda esi or honda lxi alin po malakas sa gas?
    ^^ pareho lang ata FC nila.
    Jan 2009
    suggestion po sa pagbili ng 2nd hand na car.
    1. Siguraduhing tama ang mga dokumento nito.
    2. Ask the seller if it's okay to have it assessed by a mechanic-shop. Tapos dalhin ninyo sa isang reliable na shop (sabay na test drive). Pa check mo lahat. Pag me estimate ka na (sana kasama mo yung nag bebenta) pakita mo sa kanya lahat na dapat ayusin. Drive a bargain. If the seller refuses to have it checked, walk away and forget it. That car is more trouble than it's worth.
    3. looks are decieving. wag padalus dalus sa pagbili.
    4. expect some baseline expenses. Change oil and oil filter, coolant, transmission fluid, brake fluid, etc. Also spark plugs, air filter, fuel filter, possibly brake pads, etc. Possibly suspension, tie rods, timing belt.
    5. Last but not least, expect to change your tires. Perhaps sooner than you think. This for safety reasons. Unless sanay ka ma putukan ng tires.
    Dapat me budget ka for items 4 to 5. I guess an old car would demand more. Baka yung car na nabili mo for 250K will need 50-75K expenses while a 350K car will need 10-20K lang. Good luck! Swertihan din pagbili 2nd hand.
    Feb 2009
    Oldschoolhack
    thanks sa advice marami me nalaman sa mga tips mo...
    --Pcweb
Honda lxi 99
