worth it ba kung palitan ko ng 8 iridium spark plugs yung fit ko? tingin ko wala naman problem sa spark plug pero since magpapatune up ako, isasabay ko narin. or waste of money lang at matagal talaga ang lifespan ng spark plugs?
mine is hitting its 45,000 KM very soon. I've had it for 4 years now. everything is running well.
I think the next thing on my list is the fuel filter. anyone who had it replaced already? if so how much.
thanks in advance.
Hindi fuel filter should be replaced every 20K kms? Mas ok na rin siguro yun para ok lagi yung fuel system ng car.
Posted via Tsikot Mobile App
Why you do it when it's not even recommended by the manufacturer? I think change oil at 1k is good, i did mine at 1k pms after following motoman break in secrets.
Hi. Tanong ko lang kung alin ang pwede ko irefuse dito sa 1st PMS ko. 2019 honda jazz, nung january ko nakuha. Wala pa 5,000 ang natatakbo.
LABOUR CUSTOMER 1,106.00
2PX OIL FILTER 454.83
Drain Plug Washer 30.25
SN 0W20 UNI 6X4L 2,763.40
PM KIT 325.00
CS KIT
MISC 338.00
GREASE,PAD(MOLYKOTE M77) 86.44
GREASE,PIN (NIGLUBE RM) 41.78
ENGINE TREATMENT 995.00
Perform [ ] Replace Engine Oil Filter
Perform [ ] Check Suspension mounting bolts
Perform [ ] Check Front/Rear brakes
Perform [ ] Check Air Cleaner element
Perform [ ] Rotate tires (condition,wear,press)
