Page 7 of 25 FirstFirst ... 3456789101117 ... LastLast
Results 121 to 140 of 1104
    Feb 2010
    Whats the fuel consumption of honda accord 2.0 2004 model? Thanks
    I got my Honda CRV 2011 2.0 A/T just recently. I'm averaging 7.5 km/liter. Is this normal? Will it help if I go to SLEX and ride up to a speed of 120 kph for my fuel economy to improve?
    Apr 2011
    Quote Originally Posted by edwin_ac View Post
    For city driving this should be normal. (or if you spend more time in traffic than in the highway- ie. 70% city driving and 30% in highway)
    I have a CRV 2011 2.0 MT. Highest mileage I got was 15.1km/ li for "pure" highway driving(normal load with aircon). My average daily commute of 80% highway and 20% city driving gives me 10-11 km/li.
    Quote Originally Posted by AICRAG0617 View Post
    Yes my driving percentage is around that area 70/30. Nice to know I'm within normal range.
    Nov 2011
    guys help me nmn on my car just bought it a month ago sa isang barkada ko Honda Accord Exi 96 Matic pag drive ako sa NLEX steady 80 to 100kph takbo ko 10mins pa lang na ganon overheat n sya halos nasa red na in just 2 mins kahit slow down ko na to 60kph tumataas pa rin ung temp nya pero pag sa city ako drive d nmn nag ooverheat yung car 1st tym ko palang magkaron ng car and almost 3 months old p lng sakin to ano po kaya sa tingin nyo PROB ng car...sana mbgyan nyo ko idea bago ipagawa to...PLZZZ Guys help me
    1. i would clean the radiator. i'll have the external cooling fins cleaned using soap and water and a hi pressure washer.. baka marumi lang.
    2. if it doesn't improve, i'll suspect blocked water passages in the radiator. this calls for radiator overhaul.
    3. i'd also check the auxiliary fans. are they rotating ok? they normally blow a lot of air thru the radiator.
    Jun 2007
    sir whats the fuel consumption ng Accord 1994? 2.0 yung engine po
    Sep 2011
    Hi, i just got a honda jazz 2012 model 1.5 A/T 2 months ago exact date is sept 16, and one of the reason na jazz kinuha ko is ma tipid daw sa gas, for my 1st month nag tataka ako bat ang lakas sa gas ng jazz ko nasa 7km/L city driving malate to ortigas full tank ko umaabot lng 5 days minsan 4 days lng normal driving normal apak sa gas , as searching for some answer me nabasa ako sa isang thread dito na gaganda daw ang FC and performance after 1kpms, but ryt now 2 months and 1 week na car ko my FC still the same nasa 7km/l parin, is there a problem with my jazz 1.5 2012 model? or ganun talaga? hope someone can help me regarding my fc, thank you
    Jul 2011
    Quote Originally Posted by SkyeEvo View Post
    someone mentioned in another thread that "fuel economy is 90% driver and 10% car". sir I suggest that you search the internet on driving techniques for fuel economy. you can start with this site 100+ Hypermiling / ecodriving tips & tactics for better mpg - EcoModder.com.
    Sep 2011
    hi guys. newbie here. im planning to buy a honda city s m/t or a vios e early next year. mejo confuse kung alin sa dalawa ang bibilhin ko although 80% sure na ako na in terms of practicality and fc, mejo lamang ang vios. darkhorse ang city pero ang lakas kasi ng dating sakin ng habanero red na city. tanong ko lnag sa mga may ari ng city, mabigat ba ang piyesa nito. aside sa usual na change oil, alin ba ang unang pumapalya na piyesa ng city. your inputs will be a great help. thanks.
    May 2011
    sino naka crv gen 1 dito.. para kasing mas matipid ang crv natin pag Shell vpower gas ang gamit.
    1. tune-up and regular maintenance schedule.[/B][/QUOTE]
    - Ako lang kasi ang nagpapalit ng sparkplug ko at air filter . I also followed regular change oil (I'm using mobil 1 fully synthetic oil)
    2. keep a correct tire pressure.
    - Every two weeks ako mag pa check ng tire pressure at 30psi.
    3.accelerate smoothly no 'jackrabbit' starts.[/B][/QUOTE]
    - Di naman ako humahataw masyado.
    4. keep your engine speed at power bands (2000 to 3000 rpm).
    - I also keep my RPM not greater than 3000rpm.
    5.brake smoothly, abrupt stops can contribute to excessive fuel consumption.
    - Siguro kung lagi traffic
    there is more. i will post it maybe tommorow.
    ok? [/B][/QUOTE]
    Tune-up? pano kaya malalaman kung wala na sa timing ang auto? kasi ako lang ang nagpapalit ng sparkplug and air filter . Pero yung change oil ay pinagagawa ko sa shop.
    Jan 2003
    Ako usually 7.5km/l din. Nung nilinis ko yung air filter ko, nakaka 10km/l na ako. Pero malaki pinagbago ng driving style ko. Very light yung foot sa pedal na halos walang acceleration...
    Feb 2012
    Quote Originally Posted by dembi View Post
    what is the proper cleaning of air filter? any km to be follewed? thanks
    Dec 2003
    7.5-8.5km/L ako... usually bulacan to manila or city driving lang ako...di naman ako mahilig humataw eh.. normal foot sa pedal lang...
  16. #16
    ca. 8 km/ltr (city drive) ako sa hatch ko na matic with d15b vtec engine
    May 2004
    10km/l ang ESi ko(combine hway and city). Tama si Ian-rex, 2k-3krpm lang range ko pag normal driving.
    patulong naman mga ser. bibili kasi ako ng 99 mdl na civic. gusto ko yung mas tipid sa gas. so in general, regardless of power, ano ang mas tipid lxi or vti? given na properly tuned pareho at same driving conditions. it would be a very big help for me to know the difference in consumption.
    ~6.5-7.5km/li mixed city and hiway driving..
    Gen1 crv m/t
    i usually shifts at 2500rpm, walang harurot unless kelangan..
    uses either petron XCS or unleaded..
    mga ser alam nyo ba ang epekto ng mga upgrades na ito sa fuel consumption?
    1. muffler?
    2. headers?
    3. air intake?
    4. size ng mags?
    magpapalakas ba to ng konsumo ng gas?
Honda Fuel Consumption Database
