Results 1 to 13 of 13
    Jan 2009
    gud day po mga handang tumulong. tanong ko lang po kung sadyang nag-iiba ang rpm pag binubuhay ko ang headlight? civic 96 vti po car ko. salamat po. minsan po naman nag-istock ung headlight ko kahit i-off ko ang engine. di ko po mapatay minsan ang headlight, mga 5-7 minutes po bago ko ma-off. sana po matulungan nyo ako. salamat po ng marami. ala-eh
    Is there any modifications done to your headlight wiring? Relays or similar?
    If you know a car electrician, you should ask him to check your electrical system.
    Jan 2009
    Quote Originally Posted by oliverafe727 View Post
    Problem A: RPM dipping when headlights are on
    You didn't mention what the RPM is before and after you switch on the headlights. In any case, it is normal to have a perceivable decrease in RPM as the headlights draws a lot of power but if the decrease is significant enough to stall the engine or close to it, you may have other problems.
    Problem B: Headlights will not turn off
    This is not normal and is likely caused by a stuck relay.
    If you're unsure about anything, seek professional help.
    Sep 2004
    Dagdagan ko lang ha, it might be taken out of context, hehehe. I usually hear this phrase from those who suspect somebody to be loony.
    If you're unsure about anything, seek professional help...from a trusted mechanic.
    Jan 2009
    mga gud teachers and mentors, sinunod ko po ung mga advice nyo...ok na po..ayos na po headlight ko....salamat po ng marami....
    good.
    ano mga ginawa?
    Jan 2009
    oo nga po pala. pasensya na po. pinalitan po ung relay ng headlight at direct na po ung cable punta battery kasi dati po ay may fuse pa. salamat po ng marami. God bless po.
headlight vs rpm
