Results 1 to 10 of 13
- Jan 2009
- 10
February 20th, 2009 04:23 PM #1gud day po mga handang tumulong. tanong ko lang po kung sadyang nag-iiba ang rpm pag binubuhay ko ang headlight? civic 96 vti po car ko. salamat po. minsan po naman nag-istock ung headlight ko kahit i-off ko ang engine. di ko po mapatay minsan ang headlight, mga 5-7 minutes po bago ko ma-off. sana po matulungan nyo ako. salamat po ng marami. ala-eh
February 20th, 2009 05:23 PM #2
Is there any modifications done to your headlight wiring? Relays or similar?
If you know a car electrician, you should ask him to check your electrical system.
February 20th, 2009 06:53 PM #3
Problem A: RPM dipping when headlights are on
You didn't mention what the RPM is before and after you switch on the headlights. In any case, it is normal to have a perceivable decrease in RPM as the headlights draws a lot of power but if the decrease is significant enough to stall the engine or close to it, you may have other problems.
Problem B: Headlights will not turn off
This is not normal and is likely caused by a stuck relay.
If you're unsure about anything, seek professional help.
February 20th, 2009 07:23 PM #4If you're unsure about anything, seek professional help.
If you're unsure about anything, seek professional help...from a trusted mechanic.
- Jan 2009
- 10
February 25th, 2009 10:50 AM #5mga gud teachers and mentors, sinunod ko po ung mga advice nyo...ok na po..ayos na po headlight ko....salamat po ng marami....
- Jan 2009
- 10
February 26th, 2009 08:49 AM #7oo nga po pala. pasensya na po. pinalitan po ung relay ng headlight at direct na po ung cable punta battery kasi dati po ay may fuse pa. salamat po ng marami. God bless po.
February 26th, 2009 09:01 AM #8
Bro.,- the fuse is in there for a reason. Also, it wasn't the reason why your RPM drops when you turn-on your headlights, nor the headlights on for 5 more minutes even when you attempt to turn it off.... It was the stuck or "sticky' relay or intermittent electrical connection, most probably.
7505:bravo:
February 26th, 2009 10:06 AM #9
February 26th, 2009 10:16 AM #10
That's the kind of work you get from a "pulpul" electrician who got a degree in BS:Garage Engineering. :D
And that "BS" does not stand for Bachelor of Science.
Burberry Men Leather Jacket oskarjacket
Verifpro - paypal, ebay, banks, crypto, docs and...
