Page 1 of 3 123 LastLast
Results 1 to 20 of 59
    Mar 2005
    I'm gonna be on an ecorun this saturday. Any tips on how to drive fuel-efficiently?
    What is the ideal cruising RPM?
    Ideal cruising speed?
    Ideal shifting points?
    saan ang route?
    sumali na kami ni carlo dyan. hehehehe talokami
    but we did 25+ km/ltr. hehehehe
    Aug 2004
    Shift below 2000 rpm. Coast when you can, Coast in-gear when you're slowing to a stop, Coast in neutral when you're going downhill. Keep your tire pressures on the high side, around 35 psi will do, empty everything you don't need from the car, remove rain gutters if you have them (to lessen wind resistance).
    Maintain between 50-70 km/h when you can, accelerate very slowly, and try not to stop for anything. Keep your momentum up, and you shouldn't use much.
    I think Honda requires you to keep your spare and jack, though.
    *Clavel: 25 ba inabot nyo? Yung driver ko naka 23.5 lang... but that was a great lunch, eh?
    Quote Originally Posted by niky
    nope. hindi eh. kasi huli na kami dumating kunti na pagkain.
    i maintain speed around 40-50km/h change gear around 2000rpm but hindi sya dapat lumagpas.
    23.5 is a good mileage na.
    Quote Originally Posted by Psylocke
    ideal driving style... burn & coast. Guaranteed to increase fuel milage by at least 20%. Tire pressure at 40psi or whatever is the safe maximum.
    note: burn and coast technique is where you accelerate to a certain set speed and then you shift to neutral & turn off your engine. When you reach a certain low speed, you turn the engine back on and accelerate slowly again to your set maximum speed and start again.
  6. #6
    Quote Originally Posted by ghosthunter
    turn off as in literally shut off your engine? does apply to A/T? sorry I'm kinda confused here
    Quote Originally Posted by ILuvDetailing
    yup... literally shutdown the engine. Works best with M/T cars since you can use the kickstart method to restart the engine. With A/T cars, its not recommended but shifting the car to neutral and coasting will still give better results than if the car was left in "D".
    Shutting down the engine works best because you dont burn a single drop of fuel when you are coasting with engine off. Of course some A/T trannies might get damaged if coasting was done with engine off because of fluid circulation issues...so... coasting in neural w/ engine idling is the next best option.
    ano carlo magsabi ka nang technique
    Apr 2004
    Quote Originally Posted by CLAVEL3699
    we achieved 23.43 km/L. Kung dadaan kayo ng bridge, when going down, shift your gear to neutral. Manual ba or automatic?
    Bahala sila mauna, this is not a race but be sure you will arrive within the time limit given to you.
    You and your navigator should help each other with the directions. If both of you are not familiar with streets or roads, there is nothing wrong following your opponent, parepareho naman kayo ng dadaanan.
    Always refer to your road map and check nyo yung streets kung nalagpasan niyo na.
    Short cuts are prohibited.
    Remove all unnecessary things in your car.................................
    more to come
    Dec 2003
    hindi ba masisira a/t tranny nyan?
    Quote Originally Posted by BlueBimmer
    Depends on the tranny fluid circulation issues... coasting with engine idling is the next best thing. Over-inflated tires will also marginally improve milage (but gives bad ride comfort)...
    Apr 2004
    max speed namin ni clavel is 40-50kph.
    Am sure papadaanin kayo sa sobrang traffic, around 90% ng route eh traffic.
    Sana manalo ka sa raffle hehehhehehe
    Sana manalo ka din. Balato ha
    Apr 2004
    baka padaanin kayo sa mga truck infested area kaya ingat kayo.
    Avoid sudden braking.
    San ba yung start ng event? Nung samin medyo nagkagulo dun sa pag lagay ng gasoline. Hindi na nasunod yung car#.
    hehehe mali pala ako 23 km/ltr lang ba tayo,
    ngek!
    Aug 2004
    *ghosthunter: Tama nga siguro... 40psi is the maximum pressure that the stock tires on the City can take.
    *Clavel: we could've gotten higher. I knew all the streets in the challenge pretty well, we could've gotten away without getting stuck in traffic as much... knowing which lane of EDSA to drive on is a very very good skill in runs like this. I think we might have done 26+ if I was driving. Plus, we didn't perform the coasting correctly.
    You guys still got higher than us. 23.2 yata kami.
    I remember Paul Tiglo said he got really lucky on his 60 km/l run, no traffic, and he was able to maintain a constant speed throughout.
    BTW, is the ecorun urban or highway?
    Quote Originally Posted by niky*[b
    Clavel[/b]: we could've gotten higher. I knew all the streets in the challenge pretty well, we could've gotten away without getting stuck in traffic as much... knowing which lane of EDSA to drive on is a very very good skill in runs like this. I think we might have done 26+ if I was driving. Plus, we didn't perform the coasting correctly.
    we have a problem in the last refill dami natapon na gasolina sa amin kaya medyo malaki din nabawas dun sa reading.
    Umapaw kasi eh sobra yung lagay nung gas attendant.
    Mar 2005
    Route is dagupan-lingayen, pangasinan
    Apr 2004
    aba! out of town. San Petron station yung start?
    with a CVT city or jazz, it's possible to keep the revs to 1500 rpm max in most conditions without being too slow
    Aug 2004
    Ah. Kung dagupan-lingayen, get your tires filled before the event, para sure. Might not be any air pumps at the station. And make sure you don't have any gas before the event. Since they give you the first tank for free, mas sulit kung ganyan.
Honda ecorun this saturday...
