Results 1 to 10 of 59
February 23rd, 2006 03:59 PM #1
I'm gonna be on an ecorun this saturday. Any tips on how to drive fuel-efficiently?
What is the ideal cruising RPM?
Ideal cruising speed?
Ideal shifting points?
February 23rd, 2006 04:05 PM #2
saan ang route?
sumali na kami ni carlo dyan. hehehehe talokami
but we did 25+ km/ltr. hehehehe
February 23rd, 2006 04:11 PM #3
Shift below 2000 rpm. Coast when you can, Coast in-gear when you're slowing to a stop, Coast in neutral when you're going downhill. Keep your tire pressures on the high side, around 35 psi will do, empty everything you don't need from the car, remove rain gutters if you have them (to lessen wind resistance).
Maintain between 50-70 km/h when you can, accelerate very slowly, and try not to stop for anything. Keep your momentum up, and you shouldn't use much.
I think Honda requires you to keep your spare and jack, though.
*Clavel: 25 ba inabot nyo? Yung driver ko naka 23.5 lang... but that was a great lunch, eh?
February 23rd, 2006 04:12 PM #4Originally Posted by Psylocke
ideal driving style... burn & coast. Guaranteed to increase fuel milage by at least 20%. Tire pressure at 40psi or whatever is the safe maximum.
note: burn and coast technique is where you accelerate to a certain set speed and then you shift to neutral & turn off your engine. When you reach a certain low speed, you turn the engine back on and accelerate slowly again to your set maximum speed and start again.Last edited by ghosthunter; February 23rd, 2006 at 04:16 PM.
February 23rd, 2006 04:17 PM #5Originally Posted by niky
nope. hindi eh. kasi huli na kami dumating kunti na pagkain.
i maintain speed around 40-50km/h change gear around 2000rpm but hindi sya dapat lumagpas.
23.5 is a good mileage na.
February 23rd, 2006 04:24 PM #6Originally Posted by ghosthunter
February 23rd, 2006 04:28 PM #7Originally Posted by ILuvDetailing
Shutting down the engine works best because you dont burn a single drop of fuel when you are coasting with engine off. Of course some A/T trannies might get damaged if coasting was done with engine off because of fluid circulation issues...so... coasting in neural w/ engine idling is the next best option.Last edited by ghosthunter; February 23rd, 2006 at 04:31 PM.
February 23rd, 2006 04:34 PM #10Originally Posted by BlueBimmer
