Results 1 to 3 of 3
    For a 2nd gen Honda CRV, where can I find the idle adjustment for the engine? The current idle is around 600rpm. I want to raise it to 800rpm.
    hmmm... paabotin sa redline 8000rpm?? how?
    paano nga ba?
    my cr-v is 1stgen.
    May 2007
    Hmmm...low idle huh? Well see if this one works for you since you have same problem w/ my sister 2003 CRV before.
    What I do is remove two 12mm bolts on the iac valve may dalawang butas(hole) doon, huwag mo nang tanggalin yong coolant line's at yong plug it will moved away from the intake, clean the screen in one hole w/ good strong Carburator cleaner.
Honda CRV idle adjustment setting
