Results 1 to 12 of 12
    Aug 2009
    Hi and Happy New Year!
    I'm planning to sell our Honda CRV 2006 MT, but I need to have it repaired first. After I start the ignition, on the first gear, the car experiences a dragging motion, but it goes well after that. I had it checked in a local mechanic and was advised that it's the Oxygen Sensor. They estimated P39,900.00 for the replacement of the Oxygen Sensor plus labor. Do you know a reliable and trustworthy mechanic shop where I can bring my car to have a second opinion and much lower cost on the repair and labor? Preferably in QC area.
    Appreciate your help.
    Thanks.
    Oct 2013
    Quote Originally Posted by ja15 View Post
    Thanks.
    SCAM yan mechanic mo for a 39K o2 sensor...
    Sir, nailaw ba yung Check Engine Light mo sa dashboard. Pag hindi nailaw, baka me sparkplug lang na di nagana pag malamig pa engine mo.
    Aug 2009
    Quote Originally Posted by ch0k0y View Post
    Yes Sir. May ilaw yung Check Engine Light ko. Hope to get your advice.
    Thanks and regards.
    ja15
    Sa akin pusa natulog sa loob ng engine bay, nginatgat yung mga wire kaya nag check engine, ako na lang nag connecta ulit temp. Nakikitulog na lang nga nanira pa. Btw innova itong sa akin
    Mar 2005
    May aso ba kayo? The o2 sensor nasa ilalim. Pa scan mo yan at pag ang trouble is open wire. Dugtong lang yan
    Happened to our 03 crv and a beagle.
    Aug 2009
    Quote Originally Posted by jasonub View Post
    Yes Sir, May labrador kami before. Malamang yun na yung culprit.
    Thanks.
    May 2011
    Thanks.
    Hi I advice you to go to honda dealer near you so they can check the real problem ska para malaman mo n din un mga dapat ausin o palitan tpos pag may list at estimated repair cost try mo n mag check sa iba mechanic shop pero wag mo muna sbhn kung anu un nakuha ng mismong honda dealer dpt mahanap nila un mga problem n nahanap ni dealer sa crv mo tpos pag tugma pa estimate mo n check which is cheaper sometimes mas cheap pa sa dealer kesa sa mga shop o kya onti lng difference.
    Feb 2011
    Any shop with an OBDII scanner can pull out the error code from that check engine light. Much better to get that error code para you will know which o2 sensor is failing. Most cars have more than 1 sensor, baka yung pagquote nya is for all sensors kaya mahal. I recommend a couple of shops in QC, one is in Katipunan, Forcedspeed and another one near SM North, Fixstop. Both owned by Jeff De Leon, a respected Honda guy, tuner and specialist.
    Aug 2009
    Thanks Sir. Will contact your recommended shops.
    Oct 2013
    Quote Originally Posted by bryan19 View Post
    lol, with all respect, honda dealer talaga eh mga manloloko yan... sorry dami talaga casa horror stories, wag na tayo mag mag maang maangan pa
    tama OBDII scan muna yan... sorry dun palang sa 39k na o2 sensor kakaiba na
    Mar 2005
    Basta puppy mahilig. Just look under the car. Near the engine pag may wire na putol yun na yon. Good luck
Honda CRV 2006 Oxygen Sensor
