Page 2 of 2 FirstFirst 12
Results 21 to 34 of 34
    saan area mo? sa north... motor craft banawe or speedy fix sa pasig
    sa south... hongly pitworkz sa sucat
    with the brakes, kung maingay most probably palit brake pads tapos Kapaain yung rotor, if Madame na line marks, re face or mas madali palitan din rotor. mura lang naman rotor. halos kasing price ng re face.
    Oct 2011
    Quote Originally Posted by [archie] View Post
    north sir. yes, option ko nga is speedy fix. Medyo hindi ko lang maayos sked ko kasi dito pa ko bulacan manggagaling. Baka sa kanila ko na lang ipacheck para mapatignan na din kung ano dapat ayusin.
    Mga nasa magkano kaya sir kung palit rotor + brake pads? Although wala pa namang ingay.
    Rotor around 2k - 2.5k pair. pads standard bendix 800.
    Aug 2011
    Mga bossing I also own a 99' civic tanong ko lang what are the obvious signs of a busted rear trailing arm bushing? May naririnig po kasi ako sa likod na parang squeak na parang kalabog pag nalubak. Baka rear trailing arm bushing yun?
    Aug 2011
    sir i need an info. i got a hand to an old honda civic 1993 esi. im not really familiar with hondas, pasensya po. nong tinignan ko engine, hindi na un ung original engine. instead a japan po8 civic engine was installed. i think its larger. i modified the kickdown cable because d original cable was short for the large engine. ang prob ko po e ung computer box nong original engine is not compatible ata dun sa engine installed kaya ung vtec ko hindi gumagana. may iba po bang paraan kung paano paganahin ito without buying a new comp box? pd ko po na i bypass ung vtec nya and will always in on position kaso d ko alam kung ano magiging effect sa engine and sa fuel comsumption ko. maraming salamat po sa magbibigay ng insights.. good day mga sir.
    Nov 2007
    Buhayin ko lang yung thread, what are the other possible cause for "kalampag"? Replaced stabilizer links, shocks are okay and the tie rods are okay and tight. I can hear "kalampag" when I run the car on a concrete road with some rocky portions, no "kalampag" on uneven or humps. Ride is 2000 Vti. Thanks for the inputs.
    Nov 2006
    any one can share fuse box cover below, left side of steering whell kahit picture for honda civic vti 1999 model nawala daw sa shop yong cover sabi ng anak
    this fuse box cover stating the fuse specification at kung para saang ang gamit.........thanks mga tsikoters
    sa tingin ko, baka mataas na siguro 180k niyan.
    Feb 2015
    Quote Originally Posted by Juan Martinez View Post
    Alright! Salamat ng madami sir Juan.. :D
    Apr 2013
    mahal talaga bentahan ng SIR na civic. haha. ewan ko bat may kumakagat pa. presyong FD eh. haha.
    ^yes, that's true. i just checked OLX. parang isa lang nakita ko below 200k. prices ranges from 270k to 380k. may 448k. may 550k pa! makabili kana na suv nyan.
    mga sir baka pwede nio naman ako bigyan ng konting info i have a 1999 honda civic vti sir body.
    pwede ko ba sya palitan ng po8 computer box? and kung ano ano mga papalitan pag ginawa ko yun. and mga possible na mangyayari sa oto
    salamat mga sir pacencia na sa tanong newbie lang po..
    Ask lang po... How much na po ba ang price ng honda civic rs edition... Alam ko limited edition car ko para d ako talo pag binenta ko... Vti rs sya... Sunburst yellow color... Pa tulong naman
    Oct 2015
    Quote Originally Posted by lm723 View Post
    Hi guys, just want to ask for more details regarding the civic. Hope you can help me.
    What I know about the Honda Civic 1999, 2000+ (All with SIR Body)
    1. LXi
    - Engine 1.5L SOHC non-VTEC
    - No fog lamps
    2. VTi
    - Engine 1.6L SOHC VTEC-E
    - Has fog lamps
    3. VTi RS (Same on #2 +cosmetic)
    - Engine 1.6 SOHC VTEC-E
    - Has fog lamps
    4. SIR
    - Engine 1.6L DOHC VTEC B16a?
    - Has fog lamps
    I am reviewing the three variants, so at least I know what to look at. My transmission option is AT, since my wife will drive it too. Any, other things I need to check on those years? and on the variants?
    I know, I should stay away from a heavily modified car, baka it was raced before. And parts may need to be replaced, unless it was replaced na. If automatic, how come mas madali masira eto? I know about wear n tear, but not sure which parts might need to be replaced din, para in-tip top condition ung tranny for AT.
    Costing is around 200k to 250k
    Salamat!
    Better go for the VTi variant. I have 1 and it average 8 to 10 km/l mix driving. Automatic din. Makakahanap ka ng VTi na pormado worth 180 to 220k.
honda civic vti, sir, rs 1999-2000
