Page 394 of 527 FirstFirst ... 294344384390391392393394395396397398404444494 ... LastLast
Results 3,931 to 3,940 of 5265
    Aug 2004
    #3931
    Squeaky Clutch pedal? madali lang yan....also happened to my Civic ESi 5M/T. ngayon also happening to my other rides. normal talaga yan kahit sa ano mang makes of Manual Tranny - i think.
    anyway back to topic, when it happened to my Civic. i made my own solution. just use lots of good ol grease in two different locations.
    1) Cabin side: just after the Brake Pedal there's a piston rod that pushes the brake fluid.... lubricate that area...
    2) Engine side: follow the hydraulic link or connection from the Clutch fluid reservoir to the Cylinder, to the pipe or fluid line that goes to the tranny. normally inside there's going to be a mechanical actuator that pushes or releases the clutch.... and its covered with some rubber grommet material. lubricate inside it, just use your fingers to get inside the moving part. don't worry u won't hurt yourself.
    then just press the pedal a few times and it should be ok...
    Enjoy a squeak free clutch pedal!
    #3932
    Quote Originally Posted by mda View Post
    As far as I know, these are the body colored sensors.
    You can get the black ones for much cheaper (mas ok kung black yung kotse mo hehe)
    Those sa banawe/evangelista shops would do. I don't think there's much variation between backup sensors anyway. Just make sure magaling sila magwire. Kung panget yung gawa, baka masunog pa yung kotse (THIS HAS HAPPENED ON FDs!).
    I'd prefer the body colored ones though, kung may pera sana hehe.
    Oo nga, i never thought about the risks of electrical fire. Tipid-tipid nga, nawala naman lahat. any recommendation on which shops will do the job well at reasonable cost? thanks.
    #3933
    Quote Originally Posted by m2m View Post
    Not sure eh. Maybe some other members can give suggestions on that.
    From what I've picked up though, don't ever have your wirings done by freelance 'sidewalk' electricians especially along banawe. Sila yung malala.
    Personally, on my car -
    I had my 'black' back-up sensors done sa casa back when they had their promo. 14k ata all-in with a set of foglamps for my 2006 1.8S A/T.
    Tanong mo yung casa magkano yung Honda "Approved" backup sensor. 4-5k lang yata. I got that one instead of the "Genuine" Honda sensor you mentioned.
    Kung sa porma talaga, I'd get the body colored ones instead hahaha
    #3934
    Quote Originally Posted by parakitoJDM View Post
    Thanks for the tips, but from what I've read/heard, the clutch problem for the M/T FD is a design flaw.
    Noisy clutches are not supposed to happen on basically a brand new car (2300kms on the odometer).
    Apr 2009
    #3935
    sir the shop that i would recommend in banawe to do your electrical up grades is maspro auto sound in banawe corner e. rod across ha yuan resto.
    Nov 2007
    #3936
    Quote Originally Posted by jwr motors View Post
    Nasa MASPRO pa ba si Mario?
    Apr 2009
    #3937
    Quote Originally Posted by mars18 View Post
    sir don't know kung dun si mario. ang kausap namen dun si sir benjie and vins.
    Oct 2008
    #3938
    Mga Sir,
    Yung 08 FD ko less than a yea pa lang nagkaron ng bubble sa roof abot 5 centavo coin na kalaki, Im sure pag dinala ko sa kasa i re repair lang nila to. What else can i do kaya, nakakadismaya lang kasi first car ko to.
    Oct 2008
    #3939
    Deleted;
    double post
    Aug 2009
    #3940
    Quote Originally Posted by edgi View Post
    Mga Sir,
    Sir agapan mo po yan pa check mo agad baka mamya kalawang na yang luob nung bubble para ma prevent yung pag laki. Nakakapagtaka lang wala pa one year nagkaroon na ng ganun?
Honda Civic FD Body [ARCHIVED]
