Page 1 of 2 12 LastLast
Results 1 to 20 of 29
    Dec 2014
    Sir newbie po sa group..
    One year ko na ginagamit 2nd hand na honda city idsi nabili ko.. Lately pansin ko iba ang ride pag baku-bako ang kalsada.. Pinacheck ko na sa honda wala naman sila nakikita problem.. Thank you in advance po
    panong iba?
    matagtag? maingay? nagsweserve? nag wiwiggle?
    pa specify naman..... sobrang general nung description eh.
    Dec 2014
    Matagtag po sir.. Iba yung ingay kapag di smooth ang kalsada.. Di ko kasi naririnig yun dati..
    Mar 2004
    Quote Originally Posted by rjake14 View Post
    Nung pinacheck mo siya sa honda, pina test drive mo ba yung kotse na kasama ka?
    Dec 2014
    Hindi po.. Inikot lang nung service advisor sa loob ng honda vicinity..
    ayun... patag yung loob ng honda vicinity eh.
    suggest taking it outside the casa.
    san location mo?
    Dec 2014
    Actually po kahapon dinala ko din sa bionic wheels cubao.. Pinacheck ko din wala din sila makita problem.. Cubao area po ako mga sir
    Mar 2004
    I suggest:
    (1) Bring the mechanic (preferably one who specializes in suspension, etc.) and drive to that place where you experience the problem. Then once the problem occurs, call the attention of the mechanic, "e.g. AYUN! Randam mo ba?"
    (2) Now, swap kayo ng makaniko. Let him drive while you sit at the passenger side. And ask him to go drive through the same area.
    Kung competent yung mekaniko, I'm sure hindi ka na aabot sa step (2). Mararandamam na niya yun and he'll have a good guess where teh probelm is.
    Dec 2014
    Thank you very much po sa advice Sir!
    Mar 2004
    Maganda kung ma schedule mo yung trip na yan pag hindi masyadong traffic. Kasi baka kailangan mag multiple passes kayo while he narrows down the problem point.
    I work in BGC, and I have to drive through this nasty road called 8th ave.
    Wikimapia - Let's describe the whole world!
    If you're willing to travel that far from Cubao, sigurado ako makikita yang defect na yan.
    Better yet, may honda sa BGC. Dalhin mo doon tapos mag drive kayo sa 8th ave.
    Jul 2011
    I own a jazz GD, which almost has the same suspension design ng city afaik.
    if harap ibabaw yung naririnig mo, there is a chance na lamog na front shock mount mo,
    madaling malamog front shock mount ng GD city and jazz (as per my experience),
    check mo clearance ng both sides ng shock mount, pag malaki na, it needs replacement,
    pag kumalampag kasi yan, sobrang nakakairita. kala mo kakalas, pero hindi naman.
    just be sure na mahigpit yung nut sa ibabaw.
    goodluck!
    Dec 2014
    Yung shock mounting po and rubber bushing ko napalitan na din last month.. Akala ko dun yung problem kaya maingay.. Pero after mapalitan di parin nawala ang ingay..
    Aug 2014
    If Cubao area... Go check M7 along Aurora (Malapit sa Zee) usual noise ng City (like mine, 2005 iDSI) nanggagaling sa ball joint at tie rod end. - Try M7, pag inangat nila sa lifter yung kotse mo they have a way of finding underchasssis noises. Mura pa.
    Aug 2014
    Dec 2014
    Thanks sa info Sir
    Dec 2014
    Try ko po sa M7.. Thanks again👍
    Nov 2014
    Quote Originally Posted by page7fordoddie View Post
    Pa OT lang, sir page kamusta problem sa jerking ng transmission mo??? Fix na ba??? Ano po ginawa pashare sir....thanks
    Aug 2012
    Good day mga Sirs newbie po, ask ko lang bakit minsan ung auto ko pag inistart ko sa PARK gear ay ayaw mag start ,, as in wala talga tunog khit ano ,tas ino off ko tas nililipat ko sa Neutral gear nag start nman ,, tas minsan both ayaw kya balik nman ako sa Park gear ulit ,, ayun nag start na cya ,, patulong nman mga Sirs ..(honda city idsi 2006 matic )..salamat Sirs
    Sep 2013
    kinda strange... dapat di mai-shift from P to N ang gear sa conventional A/T pag ang engine ay di naka start. I guess, there something wrong with either A/T, ignition switch etc...
    Quote Originally Posted by sunshine View Post
    Sep 2013
Honda city idsi 2006
