Results 1 to 7 of 7
    ok ba unit na to?
    anu ano mga problems dapat i-anticipate? I thinking of getting one at 320T, should I get other local units instead? Thanks
    Sep 2005
    Pretty much the same as with buying a second-hand vehicle.
    If you are referring to the JDM Civics which are imported, check the steering conversion carefully. If you think or see that the conversion was not properly done, you can always get a new oem/replacement or surplus rack & pinion and steering box locally.
    HTH
    And I think mahal ang P320K unless SiR yan. Kapag VTi/LXi lang that is very expensive go find a better price.
    Give us more details about the unit like year model, condition, mileage, etc.
    Common problems on the EK bodied series are suspension bushings, stabilizer link, trailing arm, power windows (weak), power locks, door hinges. For the engine its usually idling and valve cover seals.
    But don't get discouraged because these are just as common in other brands. Low cost solutions are readily available, sometimes you can even DIY .
    320k is an acceptable price for year 2000 and up models especially for VTi's, again it depends on what the owner has done in maintenance, mods, servicing.
    unless it's an sir, then mataas konti yung price
    May 2005
    Check the weatherstripping on the front windshield area. The part they used get loose easily and difficult, if not, impossible to put back.
HONDA EK units
