Help lang po sa 80KPMS ng jazz 2010 model. What are the parts to be replaced? And how much? As informed fuel filter is very expensive during 80k maintenance. Also palit din daw ng spark plugs. Thanks po.
Assuming you follow Honda's usual PMS cycle, below are the things to be done during the 60k and 80k PMS. You can check these details at the Honda Cars Makati site (-== Honda Cars Makati Inc. - The Official Website of Honda Cars Makati Inc. ==-). They are found under Services -> Preventive Maintenance.
60k
Honda Engine Oil Replaced
Engine Oil Filter Replaced
Tie rod Ends, Steering Gearbox & Boots Checked
Suspension Components Checked
Exhaust System Checked
Brake hoses, Lines & Connections Checked
Front & Rear Braked Checked
Driveshaft Boots Checked
Fuel Tank, Fuel Lines & Connections Checked
Fuel Filter Replaced
Drive Belts Tension & Condition Checked
Valve Clearance Checked
Air Cleaner Element Replaced
Spark Plugs Replaced
Transmission Oil Replaced (For AT Only)
All Fluid Levels (Clutch, Brake, Washer, Coolant) Inspected
Parking Brake Adjustment Checked
Rotate Tires (Check Conditions, Wear & Pressure Including Spare Tire)
80k
Assuming your car is out of warranty and if you have your own trusted mechanic (who is familiar with new Honda cars), you can have him do the labor and stuff. Just bring him the parts and fluids you need to conduct the 80k PMS. Labor cost is way cheaper than what they charge at a Honda casa.
medyo matrabaho lang ang fuel filter since from the inside ang pagpalit nito afaik so i'd still recommend to bring it sa casa for replacement.. and the fuel filter itself is around 4k plus but not more than 4.5k naman
