Results 1 to 7 of 7
- Aug 2009
- 63
July 16th, 2013 08:24 AM #1Help lang po sa 80KPMS ng jazz 2010 model. What are the parts to be replaced? And how much? As informed fuel filter is very expensive during 80k maintenance. Also palit din daw ng spark plugs. Thanks po.
July 16th, 2013 10:41 AM #2
Assuming you follow Honda's usual PMS cycle, below are the things to be done during the 60k and 80k PMS. You can check these details at the Honda Cars Makati site (-== Honda Cars Makati Inc. - The Official Website of Honda Cars Makati Inc. ==-). They are found under Services -> Preventive Maintenance.
60k
Honda Engine Oil Replaced
Engine Oil Filter Replaced
Tie rod Ends, Steering Gearbox & Boots Checked
Suspension Components Checked
Exhaust System Checked
Brake hoses, Lines & Connections Checked
Front & Rear Braked Checked
Driveshaft Boots Checked
Fuel Tank, Fuel Lines & Connections Checked
Fuel Filter Replaced
Drive Belts Tension & Condition Checked
Valve Clearance Checked
Air Cleaner Element Replaced
Spark Plugs Replaced
Transmission Oil Replaced (For AT Only)
All Fluid Levels (Clutch, Brake, Washer, Coolant) Inspected
Parking Brake Adjustment Checked
Rotate Tires (Check Conditions, Wear & Pressure Including Spare Tire)
80k
July 16th, 2013 10:45 AM #3
Assuming your car is out of warranty and if you have your own trusted mechanic (who is familiar with new Honda cars), you can have him do the labor and stuff. Just bring him the parts and fluids you need to conduct the 80k PMS. Labor cost is way cheaper than what they charge at a Honda casa.
- Aug 2009
- 63
- Jul 2009
- 820
July 17th, 2013 10:33 AM #5medyo matrabaho lang ang fuel filter since from the inside ang pagpalit nito afaik so i'd still recommend to bring it sa casa for replacement.. and the fuel filter itself is around 4k plus but not more than 4.5k naman
- Aug 2009
- 63
July 17th, 2013 06:55 PM #6
July 17th, 2013 11:24 PM #7
Personally I'd suggest sa trusted Honda casa ka nalang magpagawa. The quality of service is still better and the cost for labor can be reasonable given the scope of work. Plus they thoroughly check what needs to be checked. Recently nagpa-PMS ako sa labas for an older Honda car, they didn't do as much as what the casa normally does in checking and in the end I only saved only P250 sa labor. I just don't understand why changing the spark plugs can shoot the labor bill up by being called "tune up." I was way more satisfied last year when I had my PMS done in Honda SPA Tandang Sora.
When I canvassed around, the only overpriced component from Honda was the air filter. What you can do is just buy a cheaper replacement one outside then install it on your own since it's fairly easy. The spark plugs were decently priced sa casa too. Not sure about the fuel filter though.
Experiences can differ though!
Monk-owned R53
