Results 11 to 20 of 21
October 9th, 2016 02:56 PM #11
It could be coming from that hose based on the 3rd picture. It doesnt look like a transmission cooling hose though.
More pictures perhaps. You can also touch the underside of the hose once your engine bay is cold.
- Oct 2016
- 41
December 6th, 2016 09:33 PM #12I am hearing unusual sound/noise in the engine bay, specifically around where the belt is. Ignore the clicking sounds coming from the engine block itself. Here's the video: Honda City Weird Engne Noise - YouTube
- Oct 2016
- 41
May 27th, 2017 04:16 PM #13May nabibili bang weather stripping for this City generation?
Sent from my SM-G930F using Tsikot Forums mobile app
- Jul 2017
- 7
July 17th, 2017 08:13 PM #14Newbie here, patulong po ako to identify itong naka bypass na ito. kabibili ko lang nito Honda city 2004, ok naman sya tumakbo at maayos pa ang kaha. napansin ko lang after kong mag palit ng mga radiator hose clamp belt, nasa ilalim kasi ng engine air filter kaya hindi naming napansin. saan po kaya ito nakakabit anu kaya na bypass dito, worry kasi ako kasi family ko ang nasakay. ayaw ding sumagot ng seller pag t-text ko. salamat po.
[IMG]P70716-094223[1][/IMG]
- Oct 2016
- 41
July 20th, 2017 07:09 PM #15Sir the other image is broken. Can you send again?
- Oct 2016
- 41
July 20th, 2017 07:21 PM #16Hindi po kaya mod? Just basing on one pic, I cant find any other wire on that area.
- Jul 2017
- 7
July 22nd, 2017 04:28 AM #17nakita ko na kung saan sya naka lagay sa fan switch sensor (correct me if I'm wrong) the previous owner bypass the fan switch (let the fan always on). siguro nag malfunction yung fan switch sensor kaya na bypass..hoping na yun lang talaga problema kaya lang bago mo malalaman yung fan ang problema mag overheat muna..
BTW any dis advantages with fan always on?
salamat po sa inyo..
[IMG][/IMG]
- Jul 2017
- 7
July 22nd, 2017 06:38 AM #18
- Oct 2016
- 41
July 22nd, 2017 09:38 AM #19Akala ko sa harap lang yung wires for fan.
Anyways ask ko na rin po since tinanggal niyo po yung air filtee assembly, safe lang po ba i-unplugged yung wire ng sensor?
- Jul 2017
- 7
July 24th, 2017 11:27 AM #20What you mean sensor, ng fan? ang epekto nyan life ng fan siguro at consumption ng gas mo, kasi buhay agad yung fan mo pagkabuhay ng makina. kung sensor ng water temp naku no..no..no, not advisable yari ka pag nag over heat makina walang detection yan.
bibili na din ako ng fan switch sensor para mabalik ko din fan switching sa auto.
