Results 1 to 6 of 6
    Jul 2013
    Possible po ba to use the Navigation without the radio? - how?
    Jan 2009
    Generally speaking, most HU will allow you to do that. Check the manual.
    In many cases, there's a dedicated button for it called "Nav". You can turn off the radio (or put it on standby) and then access the navigation by pressing the Nav button or choosing it from the menu.
    Jul 2013
    yes. should be possible... pero with this specific unit, di ko makita option to turn off the radio while using the Navigation...
    Anyone here whose Honda is using the same head unit?
    Jul 2004
    Honda never used AVT branded HU officially. Must be a dealer add-on. Would be better if you can share photos/specs of your AVT HU
    Jul 2013
    Quote Originally Posted by glntVR View Post
    hmmm, yes. dealer add on, pero AVT naman normally ang available sa Honda Ph.
    Pati yung lumang head unit (without Navigation) AVT
    Jan 2009
    What's the model of the AVT?
    The last AVT I used was a dealer add-on on our 2010 Tucson. We sold the car already but I do remember that with the radio off or your input source selection set to an unused input (like Aux 1 or 2, Bluetooth, SD card, etc.), you just press the NAV button and it'll bring up the navigation screen.
    On my Kenwood DDX8034BT, it's the same thing. Set input to something that is unused or Standby. Then access the NAV features by tapping it on-screen or through the remote.
Honda AVT Head Unit - with GPS (help)
