Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    May 2008
    where can you buy honda atf in the diliman, tandangsora and marikina areas?
    Mar 2012
    Bro, di ba may honda marikina na? Casa pa rin best bet mo para siguradong di fake. Nagkalat pa naman ang mga fake, may fake rice, fake noodles, fake fake...
    May 2015
    meron po ata online
    Jul 2015
    Sir ask q lng po newbie s honda car kse mali dw po nailagay q na atf oil shell apirax po oil na nirecommend ng mekaniko nmin pero as per may tropa dpt dw pg honda mas mgnda dw atf Z1 or cvtf dw dpt oil n ilagay q a transmission. Worried lng aq bka masira ung transmission q sa nilgy q na oil. Pero balak q drain at palitan agd dis week ung atf oil ng cvtf or atf z1 ng honda. Ok lng po ba yun sir nalagyn q ng maling oil.tnx
    Quote Originally Posted by mykel04 View Post
    Ano kotse mo? May mga Honda City/Jazz na gamit ay CVTF at hindi ATF. Magkaibang fluid ang CVTF sa ATF.
    Medyo mapili yung Honda kaya di ok na ihalo mo ibang klaseng ATF. Medyo lower viscosity yung Honda ATF. Drain mo na lang kaagad tapos gamit ka Honda ATF/CVTF fluid.
    Jul 2015
    Sir honda jazz po 2006 model vtec po sbi din s shell atf bsta matic ok dw po late q n kse nakausap tropa q. Kinatatakot q lng po kse bka masira ung transmission sir almost 1month n po tumatakbo oto service kse asawa q s work.
    Mar 2005
    Palitan mo na lang ng Honda ATF sir, meron sa Honda SPA along Mindanao ave. Wag ka maniwala sa sabi ng Shell, di naman nila babayaran yan pag nasira transmission mo. Yung sa ka grupo ko sa Santa Fe Club ganun spirax din nilagay sa Sta Fe kahit ang required is Hyundai or Diamond SP3 rating. Wala naman ganung rating yung Spirax pag chineck mo sa likod.
    Edit: Kung CVT transmission yan dapat Honda CVT Fluid.
    Paki basa po... ATF ang Nilagay instead na CVT Fluid.
    ATF fluid used in CVT Transmission - Car Talk
    My 2005 Honda Civic Hybrid died yesterday and the dealership said that the transmission is ruined and needs to be replaced. It has 102,000 miles and has a Constant Variable Transmission. At 84,000 miles I had the transmission fluid drained and refilled at a local reputable mechanic (not the dealership) and they added 3.5 quarts of Honda ATF fluid instead of CVT fluid.
    Is that what killed my transmission? Why was it able to run for 20,000 miles with the wrong fluid? I have been very good about getting oil changes and keeping up on the maintenance. What is the life expectancy of this transmission? Should the mechanic who made the error replace the transmission at no cost to me? Should he reimburse me for my rental car?
    What steps should I take?
    ^ bawal ang text speak dito bro
    anyway, kung cvt ang tranny mo, dapat cvt fluid lang ang ilalagay mo
    when it comes to honda automatic trannies, stick w/ honda fluids to be sure. maselan ang mga honda pag dating sa ganyan
    Jul 2015
    Jazz po sir 2006 model A.T po sir san po ba mkkta kung CVT po tranny q? Wala po kse owners manual eh 2ndhand q n po sya nbili.
    Jul 2014
    Ito sir ang model ng gear pag cvt depende sa size ng engine
    Jul 2015
    Sir ask lng po bka may alam po kyo san nkakabli ng cvtf oil for honda? Tnx po
    Jul 2015
    Sure k sir pwede ung honda atf instead of cvt fluid s tranny q? Sbi kse nila pg cvt tranny mo cvtf lng ilgy wag dw atf ..tnx a info
    Jul 2015
    Oopppsss sorry sir.
    Jul 2015
    Salamat sir sa advice bilang newbie ^_^
    Honda CVTs are developed by Honda Japan so going with honda fluids is good practice.
    CVT from nissan, suzuki, mitsu are all from Jatco. Mirage and G4 and new Celerio CVT are the same. Xtrail and ASX use similar Jatco cvts.
    Future GM small cars next year will feature cvt from jatco also.
    Jul 2015
    Sir goodafternoon po another question po sana ok lang po ba bugahan transmission pagkatapos mag drain? Thank you po in advance CVT transmission.
    Mar 2012
    Ang tanong ko na rin out of curiosity sa case ni Mykel.. sa regular AT kasi ng honda may naiiwan sa loob na mga 40%, is this the same case sa CVT? If yes, edi diluted yung CVT fluid nya with non oem/non CVT fluid?
    Bro Mykel, palagay ko di pwede yung pabuga, kasi meron pa ngang dialysis machine na kailangan para i-bleed out yung old oil. Pero let's wait what experts have to say.
    Jul 2015
    Ahh ganun po pala kala ko kase like s mga motor right pagnag change oil sila binubugahan heheheh.. by the way thank you sir sa info. ^_^
    Jul 2015
    Sir need your expert opinion pinayos ko na po yung sa transmission ko nagpa bleed na po ko bali 2 beses na po drain kase nahaluan nga po ng atf fluid kaso bakit ganun po cvtf na po nakalagay ngayon kaso parang iba na pakiramdam while driving parang may suntok na ewan or parang may mararamdaman ka ano po kaya yun? Nasira na po kaya transmission ko? Parang mas ok pa takbo nung may halong atf kesa sa ngayon. Salamat po
    Jul 2015
    Goodmorning guys sir ask ko lang may problema po ba ang honda jazz 2006 model sa CVT? Curious lang base on sa mga comment nababasa ko. Thanks
honda atf
