Results 1 to 7 of 7
    Jul 2013
    Hello, All.
    Noob here po.
    Just need to ask the above.
    The Honda Service Agent at Honda Kalookan said that the correct tyre pressure should be 30 psi at front and 28 psi only at the rear.
    Allegedly, pressure should be higher at front, because the load there is higher most of the time (on account of the engine).
    Anyone has a different opinion?
    Or, anyone has negative/positive experience/s relative to this?
    My apologies if this thread that i started is a loose one. Feel free to include this na lang po (where proper).
    Thanks, in advance, for your input/s.
    Jan 2009
    Quote Originally Posted by jupe View Post
    Hello, All.
    Noob here po.
    The SA is correct. You can find the same information on a sticker located by the driver side door jamb or user manual.
    Jul 2011
    32/30 ang nakalagay sa driver side door jamb
    Jan 2009
    Quote Originally Posted by s10pao View Post
    My bad. I knew that the rear is 2 psi lower than the front. I apparently didn't knew the exact figures.
    Jul 2011
    ok pa ung 30/28 para bawas ung tagtag
    Jan 2009
    Best you follow manufacturer recommendations. Lower tire pressure means more tire wear and lower fuel economy.
    Oct 2011
    Just follow the required tyre pressur indicated in the manual. SA tyre pressure number could be wrong at times.
What is the correct tyre pressure for the 2013 Jazz?
