Results 1 to 10 of 17
- Sep 2010
- 7
September 6th, 2010 12:27 AM #1Mga sir newbie lang ako dito meron ba kayo idea kapag pinagawa ko timingbelt sa casa mismo at ano pa ang dapat pagawa ko para isang gawaan nalang, paki advise naman po kase nasa schedule napo kasi yu civic ko para palitan 85k napo siya,...marami salamat po in advance..
- Sep 2010
- 7
September 6th, 2010 06:54 PM #2I call honda casa in pampanga eto yung quotation nila sa akin,
Timing belt 1600
Temp bering 5100
Oil seal 640
Labor for timing belt 1700
Water pump 4900
Labor 1200
Total cost about 15140
Meron po ba kayu idea dito na pwede ako makamura patulung naman po pls
September 6th, 2010 07:27 PM #3
medyo madugo yung quote sayo.
i had mine (LXi 2000) repaired 2 years ago. cost me more or less 5k for everything. japan replacement lang ginamit ko sa mga seals and water pump and yung timing belt itself lang yung orig na ginamit. had it done sa pasay at kasama pa yung tappet adjustment. 15k is way too much in my opinion.
- Jun 2010
- 258
September 7th, 2010 02:31 AM #4mahla naman nyan bro go to fertes o kaizen mas makakamura ka... ano year ba civic mo? kung mga 2005 up pede pa sa casa pero kung circa 2000 down dami alternative choices diyan bro....ika nga nila yun sulit pero di sing mahal....trauma na ko jan s amga casa na yan had a 1993 civic putris nun nag paquote ako ng mga dapat palitan mas mahal pa yun gagastusin keysa sa presyo nun nabili ko yun kotse...hindi naman tayo na katulad ng iba diyan parang damit lang kung magpalit ng kotse....hehehhe
- Aug 2010
- 14
September 17th, 2010 08:13 AM #5
September 17th, 2010 09:07 AM #6
- Nov 2009
- 456
September 17th, 2010 10:29 AM #7
- Aug 2010
- 14
September 17th, 2010 07:01 PM #8Sir desert fox ku halimbawa na timing belt lang ang papalitan then after a year nagluko ang water pump kung babaklasin ulit d ba apektado ang timing belt o magagalaw ku di cguro ok lang e papa ano ku kakalasin din ulit yu timing belt para ayusin yu water pump d kaya masira yu belt sorry po wala po kasi ako alam kaya nagtatanong po ako
September 17th, 2010 07:29 PM #9
sinasabay na water pump kasi same ang access nito pag nagpalit ng timing belt, para isang bayad na lang ng labor, at ang service life ng timing belt at water pump halos sabay din.
September 17th, 2010 08:32 PM #10
pa check mo muna ang water pump kung ok pa o hindi.. pwede nman di isabay sa palit timing belt ang water pump..if napalitan mo ang timing belt tapos biglang kelangan palitan ang water pump hindi masisira ang timing belt kung gagawin ang water pump..isabay na din ang tensioner kung palit timing belt importante din ang oil seal ng cam shaft at crank shaft mura lang ang oil sea na yan isabay mo na sa timing belt
hope to help
high idle RPM at engine start
