Page 1 of 2 12 LastLast
Results 1 to 20 of 25
    Sep 2013
    Tight budget lang po baka meron po kayo alam na original pero murang rotor worn out na kasi yung sa unahan ko kakapalit ko lang ng pads eh recomendation ng mekaniko palitan na din daw ride ko po is jazz 2006 matic front rotor lang po yung worn out
    Jul 2013
    Surplus lang pag asa mo kung mura hanap mo.
    Pero suggestion ko measure mo muna thinckness. Baka naman within specs pa kahit ipa machine shop.
    Sent from my GT-N5100 using Tapatalk 2
    Sep 2013
    Sir thank you po try ko maghanap hanap muna sa surplus any brand po na marerecomend nyo kung replacement naman... Ty po
    Check if you can still resurface those rotors. It's cheaper than getting new ones or surplus.
    By the way, how did your rotors get worn out? You would have heard screaching sounds when the brake pads started eating into the rotors.
    Sep 2013
    Yup kaya pag nakadinig kayo screeching sound better na magpalit agad kayo sa ngayon nag iipon na ko pamalit balita ko kasi mahal ang genuine nito
    Feb 2007
    A 7 year old car with worn out rotors?!? My previous pickup of more than 18 years has its original rotors before I sold them. Had changed the brake pads months before selling and the rotors are still OK. You must be braking really hard or naka ilang reface ka na siguro.
    Sent from my Samsung Galaxy S4 using Tapatalk 4
    Sep 2013
    Napagpractisan kasi ni misis eh mabigat ang paa buti nga hindi pumutok ang preno babae din po kasi previous owner nito
    Rotors will not give way unless the brake pads are not replaced regularly. It would be good to just visually inspect the pads every other time you do an oil change. If you see unwanted grooves being cut into the rotor face, then get a mechanic to check the pads and replace them if necessary. Some change pads every 30k or 40k km. AT cars usually change pads earlier than MT cars.
    Jun 2004
    Question lang po, ilan na mileage nung kotse? Ano daw reason bakit kelangan palitan yung rotors?
    Both our cars still have original rotors at 134,000 and 150,000 km, and both cars never had any rotors refaced either.
    I've replaced mine since the difference is so small (machine shop vs replacement). Got a brand new pair for 2.2k and the machine shop is asking 1.4k for refacing the pair. Pwede pa pamachine shop pero I feel safer with an 800 difference.
    Mar 2012
    Saan ka nakabili at anong brand ito sir Archie? Last Dec 2008, nakayod ng brake pad wear indicator ang rotors ko, so my ugly deep lines ito. Nagpa quote ako nun sa suking auto supply ko and it was 3,400 * (P6,800/pair) dati. Anyway I did not replace it nor have it machine shopped. That was 71,000 kms and 5 years ago, ayos pa rin ngayon. Just want to know my options as it may need to be replaced soon.
    Quote Originally Posted by [archie] View Post
    It does not matter if the mileage is low or high. It depends on neglect of brake pads replacement or malakas kumain ng rotors yung Nakuhang break pads.
    Powerplus is an inexpensive, readily available, and quite reliable brand. We use them on big suv's and vans. They might have a model to fit your car. For a late model Land Cruiser, the srp of these things in Banawe was Php3500/pc. The Jazz has smaller brakes so I presume the cost will be less.
    We pair them up with Bendix general ct pads most of the time.
    Doc Otep, the powerplus for that price is slotted or drilled? Or just stock? How's the braking with CT pads on a big rig?
    Standard rotors lang po. Nothing fancy. Braking felt the same. Hehe
    Try mo hanapin dba brand..my fd front disc cost only around $80
    Toyota Chatswood
    Sep 2013
    nakabili na po ako kanina powerplus brand US po daw yun then palit na din brake pads bendix ang brand tinago ko muna original na honda rotors saka ko na pareface pag may time mas comfortable ako kasi pag bnew he he he
    May proper way if brake in yung disc and pads. Google niyo nalang.
    May 2017
    For those looking for replacement brand, Bendix and Bosch are well known brand available sa market.
    Apr 2010
    mga sir saan shop meron bendix rotor? looking for hilux revo sana.
Help recommended rotor disc
