Results 1 to 7 of 7
    Feb 2011
    naputulan kc ako ng timing belt..pero 30 kph lng nman takbo ko..then i bring my car to my friend mechanic.pero dko sure kung marunong xa sa honda..after nya magawa.parang my kakaiba n sa takbo..lagi ako na mamatayan khit i adjust ung menor.tapos my ma ingay sa makina..anu kaya dapat ko gawin??help guys! tnx
    my car is a 97 model V.T.I
    Oct 2008
    Dre, naputulan na rin ako ng timing belt (corolla XL). Top overhaul ang nangyari. Pina machine shop yung cylinder head at nagpalit na rin ng mga valves (intake at exhaust). Sa tanda ko nasa 10T + kasama na yung charge sa machine shop.
    +1 to AS. Top overhaul. Or surplus engine if you can afford to replace.
    Feb 2011
    Quote Originally Posted by al shaheen View Post
    sakin 20t ang inabot eh..bakit kaya sobra mahal?.
    Quote Originally Posted by jcner21 View Post
    [SIZE="4"]REMINDER: do not post messages in SMS/TXT shortcut format & grammar. Use proper sentenses and paragraph construction. If your posted message is hard to read, less people will read it & respond.
    Read the RULES.
    Ignorance is NOT an excuse.
    Repeated offenses will lead to banning.
    [/SIZE]
    Feb 2011
    na topoverall na din naman,pero the problem is.there is a huge noise coming from the engine..pero hindi naman ganun kalakas.nakakairita lang talaga..
    Jul 2010
    It could also be that the timing between the camshaft and crankshaft was not properly set when your friend replaced the timing belt. Go bring it to a trusted mechanic to inspect.
    It also happened to me when I had my car serviced for timing belt replacement. The engine dies immediately after starting the engine. So they had to check again and sure enough the timing was off.
    HTH
engine problem..help guys!
